Question about Cameras
I don't understand how to set my new Olympus Pen EPL1 camera on largest size jpeg's without using the RAW setting. What does LF, LN, MN and SN stand for please??? And does one change back to factory settings? Many thanks.
SOURCE: RAW+L not working
Having the same issue here, are you any further forward with finding a solution?
Posted on Sep 15, 2008
ButtFuzz
  • 463 Answers
SOURCE: Camera set to RAW, but pics showing up as JPEG when viewed,stored
Some cameras will shoot RAW + JPEG, and save a copy of each in a different directory on the card.
Re-check your owners manual, and also check the manufacturer's website for a firmware update...
Posted on Mar 06, 2009
  • 102366 Answers
SOURCE: raw file quality not as good as jpeg
RAW quality will always be at least as good as JPEG quality. The reason your JPEGs are coming out sharper is that the camera is actually doing post-processing on the RAW data, performing sharpening, white balance, contrast and brightness adjustment, etc., before saving the JPEG. The RAW data, as the name implies, is taken straight from the sensor, without the sharpening and other post-processing applied to it.
Posted on Feb 17, 2010
  • 5 Answers
SOURCE: When I shoot in Raw + jpeg, no raw filkes show up.
I had the same problem, basically all you need is a RAW converter, the canon software should do and should be provided with the camera and if you havent got that then there is a wide selection of free software on the internet im sure of it just search for it, or a lot easier not to use RAW in the first place...
Posted on Apr 21, 2010
LongPockets
  • 1177 Answers
SOURCE: I've done something to my Olympus pen epl1! The
I sounds like you have altered the white balance setting somehow. This will be in the setup menus. You want it set to auto. If it is already on auto, then I would think the camera has a fault.
Posted on Oct 20, 2010
Can't remove the RAW Setting to keep just the JPEG option without RAW. It is set to RAW and the dial only scrolls through JPEG options. How do I get access to the RAW options to turn off RAW??
When on the image recording quality setting screen, use the main dial to select RAW (go all the way to the - sign on the left to turn off RAW), and use the multicontroller left/right to select JPEG settings. See page 116 in the manual.
Jun 20, 2015 | Canon EOS 70D Digital SLR Camera Body Kit,...
Why am I no longer able to set my 60D camera to take RAW formatted pcitures
In order to select RAW mode, first check if your camera is in either Manual(M)/(A)/(AV)/(Ev) modes. Then go to setting-picture format-RAW/RAW+Basic.
In order to edit the RAW picture, you need to update the RAW version if you are using Adobe Photoshop for editing your pictures.
Thank you!
Regards,
Pratish Shrestha (pratis010)
Jun 27, 2014 | Canon EOS 60D Digital Camera
Does not flash
http://www.imaging-resource.com/PRODS/EPL1/EPL1FLASH.HTM
It may be switched off. There could also be a break in the wiring to the flash. Without more, there's no way to know.
The first step would be to verify that the flash has not been set to "off" in the flash mode.
Jul 14, 2013 | Olympus Cameras
What does raw+fine pictures mean?
The raw+fine setting indicates that your camera will take both raw (NEF) and high resolution JPEG pictures with every shot. You can change this to shoot just JPEG or just raw shots using your menu under the little camera icon. Click on image quality and it will give you multiple settings so you can choose only raw or only JPEG. You have three JPEG settings: fine, normal or basic.
I always shoot raw+fine which I think may be the default setting. I use the jpeg pictures for simple and quick editing and I use raw for detailed editing. JPEG pictures deteriorate quickly during editing while raw pictures can handle extensive editing without significant deterioration.
When you shoot raw+fine, it means the camera is actually storing two pictures of the same shot, one in each of the two formats. When you view the pictures in Windows, you can tell the difference between the raw shots and the jpeg shots because the raw shots have a broad black bar across the top and bottom of the picture while the jpeg shots fill the screen.
Apr 14, 2013 | Nikon DSLR D90 Digital Camera
I've done something to my Olympus pen epl1! The photos taken with Programme, Shutter Priority, Aperture Priority and Manual modes all have a blueish tinge. iAuto, art, scene modes are all fine. How do I...
Oct 20, 2010 | Olympus PEN EPL1 Digital Camera
I cannot print pictures taken in nef format. Can
Hi dear, most printers can only use jpeg or bmp format .Use Irfanview to convert raw file to either one.
Jan 17, 2010 | Nikon Coolpix 5700 Digital Camera
Mar 06, 2009 | Olympus Evolt E-510 Digital Camera
I have Olympus c-750> I need to shoot in jpeg format.................how do you tell if the camera is set for jpeg? I see tiff all over the place, but no way to "choose" between the two....
The SHQ option is the highest quality JPG image setting
You can download the manual from here...
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/#c
All the info you need is on page 18,22 and 50
If you need further help drop me a line
Happy snappin
Jun 09, 2008 | Olympus Cameras
*ist RAW converter problem
Ignoring the JPEG artifacts, which isn't about the extra grain in both the TIFF and JPEG images produced by the convertor, is it possible that different sharpness settings were used for the output images that for the on screen review? High values of sharpening without using an appropriate noise threshold value will have the effect of increasing noise/grain.
Sep 08, 2005 | Pentax *ist D Digital Camera
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Cameras Logo
349 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
