Within minutes of browsing the internet a blue screen comes up. at the bottom of the screen it mentions that it is dumping physical memory. Then it restarts the computer. I tried system restore and I tried using recovery discs but it did not work.
  • 1,179 Answers
Welcome to Fixya, it's damnor01 here your computer Expert.
Your computer is dumping memory. This is refered to the the Blue Screen Of Death or BSOD for short.
It is not a good thing it is bad.
It usually happens because of too much heat.
In other words your computer is getting too hot. Clean the computer of all dust, dust reduces airflow through the heatsinks and therefore your computer operates at a high temperature.
Install as many fans as your computer chassis will allow.
Ensure that your Virus scanner is up to date and perform a virus/anti-malware scan, as viruses stress the computer system unnecessarily.
Cooling is very important!
Be sure to rate this session!
Thanking you very much!
damnor01
Posted on Mar 18, 2011
Physical memory dumping when l start to play gta
providing the actual dump message will greatly increase the chances of a correct diagnostic of the problem. (yes the message actually tells us why it goes to physical mem dump) other than that i'd check the fans and fins for dust buildup (causes overheating)
Nov 02, 2013 | Rockstar Games Video Game Consoles & Games
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
A have a laptop toshiba l640. when i start the laptop within ten minutes a blue screen showing physical memory dumped is displayed. pls explain wat to do with it.
1. This problem is usually occur
a. When there is any hardware conflict
b. A newly install driver creates problem
C. Partitions of the hard Drive are deleted due to viral effect.
Solution:
You need to reinstall the windows.
Jul 08, 2011 | Computers & Internet
When i turn it on i get this screen asking how iw ant to start it, safe mode, normally, command prompt, or last known good config. any of em i entered it would boot up showing the microsoft windows XP...
this is a known problem with Windows XP. it occurs as a result of a corruption within the Registry hive.
A very thorough and complete set of instructions can be found here- http://xphelpandsupport.mvps.org/how_do_i_repair_a_stop.htm
follow the instructions to resolve your issue.
//javaftper
Aug 01, 2010 | Dell Inspiron 8100 Notebook
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
http://www.ccleaner.com/ccleaner-20
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Physical dumping memory...
Try to increase your virtual memory.  This may help you some.
Oct 27, 2007 | Computers & Internet
BEGINNING DUMP OF PHYSICAL MEMORY
Hi, Normally a blue screen of death (BSOD) with memory dump is indicative of a fault in the: Hardware- 1. Possibly memory; 2. video; or 3. motherboard. In some instances, Software- a. Drivers; or b. the Operating System itself. You may want to check the memory installed in your laptop. Some versions have them underneath the keyboard while most would have it at the bottom covered by a lid/plate secured with 1 or 2 small screws. The memory will spring out if you unlock the two side clips. You need to clean the little gold contacts with a pencil eraser. Re-insert back securely and try again. If the above does not correct the BSOD, you may need to replace them. Hope this be of some help/idea. Post back how things turn out or should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Compaq Evo N110 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
