Question about Lexmark Wheelwriter 6 Series II Typewriter
I need to operate the "CODE" button. How do I copy typed info with "CODE"?
  • Lexmark Master
  • 3,594 Answers
If you want to store something and reprint it later. On the L. side of the keyboard are 3 keys STORE, PLAY and DELETE. Hold the store key, type in a address 01-99 release store key, type info, touch store again. To print hold play, type address, release play.
BE SURE THAT BATTERIES ARE GOOD AND THE HOLDER ISN'T CORRODED OR YOU WILL LOSE THE MEMORY ON POWER DOWN!!!
DickyO
Posted on Mar 18, 2011
"this is not a valid zip code"
find ur postal code and type it..after done it IE will open corectly and disable weather program
May 21, 2012 | Microsoft Computers & Internet
Tip
Windows 10 - Start Menu Fix
How to fix the Windows 10 Start Menu when you can only right click on it:
1. Right Click the Start/Window button on the bottom left corner of the taskbar.
2. Select "run command prompt as administrator"
3. Type in the word "powershell" without the quotes and hit Enter. Wait a few seconds to process the request.
4. Copy and paste the block below and hit Enter. It will take about a minute to process. Don't close the window, just wait for the command prompt to reappear. Then your start menu button will work again!
Regards,
Terry Wilkie
Get-AppXPackage -AllUsers ' Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
on Aug 16, 2015 | Microsoft Computers & Internet
Tip
Backup data from non-booting operating system
You go to boot your computer and you get an error. Asking around online you find out that the only thing left to do is to reformat and reinstall the operating system, causing all your data to be lost. Is there nothing you can do? Actually, yes there is. I will explain how to use the <a href="http://www.sysresccd.org/Download">System Rescue CD</a> to save your data, then restore it on the new installation! This can be done with any linux live CD, but the system rescue CD is a little easier, so that's what I'll use to explain it.<br /><br />What You'll Need:<br /> <ul> <li>System Rescue CD</li> <li>External USB drive LARGER THAN your internal drive (or at least equal to)</li> <li>Some time and patience :)<br /></li></ul> <ol> <li>Download the .iso file from the website linked above, then burn it to a disk. This will give you a working copy of the System Rescue CD. You'll want to download the latest working copy, listed as the "Final Stable Version". It will always be on top (at the time of writing it's <b>2.3.0</b>).</li> <li>Insert the disk into the non-working computer. You might have to turn it on and quickly open the CD drive to put it in. Then restart. Depending on your system, it might boot to the CD automatically. If not, look around when you first boot for "Boot Menu" usually on the bottom of the screen, it will tell you which function button to hit. F7, F9, F10, F11, Esc, and Del are popular ones. Try different buttons, you can't hurt anything, and if it doesn't work just hit Ctrl+Alt+Del to restart and try again.</li> <li>When it finally boots to the CD, keep pressing enter until you get a prompt that reads "root@sysresccd / %" that means you're at the command line. Now there are two ways to go, using the command line and using the GUI. I'll explain the command line first, then the gui.</li></ol>Command Line:<br /> <ol> <li>(NOTE: All commands will be surrounded by "double quotes". Do not type the quotes.) Type "fdisk -l /dev/sda" and take a look at the partitioning scheme. There should be at least one partition, formatted NTFS. Most of the time it's sda1, but it could be that you have one small partition and one large one. You need to figure out where your windows partition is, so you can back the data up. Pick which one you think it is (I'm going to assume sda1) and type "ntfs-3g /dev/sda1 /mnt/windows", then type "cd /mnt/windows" then "ls" (NOTE: that's an "ell", not an "eye"). If you see some windows directories (like Program Files), you've got the right partition. If not, type "cd /mnt; umount /mnt/windows" and retry.</li> <li>When you have your windows partition mounted, plug in your external harddrive and wait a minute or two to be sure that it's recognized.</li> <li>Type "dmesg". A lot of text should scroll, then it should put you back at your command prompt. In the last few lines you should see something like "USB Mass Storage Drive entered: sdb" or something similar. The important part is the sdb. Type "fdisk -l /dev/sdb" again to look at the partitions (there should only be one), then type "ntfs-3g /dev/sdb1 /mnt/backup" to mount it as the backup disk.</li> <li>Type "mkdir DataBackup" to create the folder to store the backup in, then type "cd DataBackup" to change to that directory.</li> <li>Now type "rsync -av --progress /mnt/windows ./" to copy everything from the windows directory to the DataBackup directory. Wait until it's done, then reboot.</li></ol>GUI:<br /> <ol> <li>Type "wizard" at the command prompt, then keep hitting enter until you get a gui. Go through the "start menu" until you find something called gparted. Open that and take a look at everything you've got.</li> <li>On the top right you'll see the drive you're currently perusing. sda is your internal drive, sdb is your USB. Right click on the largest box under sda and click "Mount". It should give you a dialog box, choose the directory /mnt/windows. Do the same for sdb, mounting it at /mnt/backup.</li> <li>Open the file manager (it should look like a folder on the taskbar). In the left pane, navigate to /mnt/windows, in the right, navigate to /mtn/backup.</li> <li>Create a directory in the right pane named DataBackup (should be able to right-click&gt;New Folder), then open that folder.</li> <li>Select everything in the left pane and copy it to the right using the button in between the panes. You can hover with the mouse over the buttons to see what they do.***</li> <li>Wait until the transfer is complete, then you've got your backup!</li></ol>*** If there is an error that sdb is not writeable, open the command prompt (should have opened when you started the gui) and type "umount /dev/sdb", then type "ntfs-3g /dev/sdb1 /mnt/backup". That will make it writeable.<br /><br />You can use these folders to copy your data back off once your installation has been fixed. Note that you cannot copy over programs, only data such as saved files, pictures, movies, etc. The programs will have to be reinstalled. Best of luck, and I hope this helps someone!<br /><br />
on Aug 18, 2011 | Computers & Internet
Download the driver for the webcam
Hi abelw64,
The only way you can get help here is by providing all the needed information. In this case, we will need the specific brand and technical details of your laptop or netbook so that we can check out it's specifications and then suggest an appropriate driver for your system.
If you are running a Windows OS(Operating System) on your laptop, do the following: 1. Go to Start> Run and type in "dxdiag"(WITHOUT the quotes). 2.In the DirectX Diagnostics window, click the "Save all information" tab and select the place to save the Dxdiag.txt file.I suggest you save it to your desktop for easier reference later on. 3.Open the Dxdiag.txt file with notepad(double click it and it will open with the default text editor). 4.Highlight all text in the file(Quick short-cut: CTRL+A key combination), copy it and paste it in this forum.
For detailed system information, repeat the same procedure, but this time, type in the command "msinfo32" and select the save info button.Then copy all it's info to this forum and from there it will be posible to tell the type of webcam that's most likely to be installed on your system.
Do it as soon as possible.
Feb 09, 2011 | Computers & Internet
Tip
NOKIA ALL CODES
NOKIA Codes <br /> <a href="http://www.dpbolvw.net/8998efolfn257BA3C6243779735HYPERLINKhttp://www.dpbolvw.net/8998efolfn257BA3C6243779735"></a><br /> &#12288;<br /> *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5% <br /> #3370# Deactivate Enhanced Full Rate Codec (EFR) . <br /> *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time. <br /> *#4720# With this Nokia code you can deactivate the Half Rate Codec. <br /> *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type . <br /> *#9999# Phones software version if *#0000# does not work. <br /> *#06# For checking the International Mobile Equipment Identity (IMEI Number) . <br /> #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). <br /> #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) . <br /> #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). <br /> #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) . <br /> *#147# This lets you know who called you last (Only vodofone). <br /> *#1471# Last call (Only vodofone) . <br /> *#21# This phone code allows you to check the number that "All Calls" are diverted to. <br /> *#2640# Displays phone security code in use . <br /> *#30# Lets you see the private number. <br /> *#43# Allows you to check the "Call Waiting" status of your cell phone. <br /> *#61# Allows you to check the number that "On No Reply" calls are diverted to . <br /> *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to . <br /> *#67# Allows you to check the number that "On Busy Calls" are diverted to <br /> *#67705646# Phone code that removes operator logo on 3310 & 3330 <br /> *#73# Reset phone timers and game scores. <br /> *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible . <br /> *#7760# Manufactures code. <br /> *#7780# Restore factory settings. <br /> *#8110# Software version for the nokia 8110. <br /> *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again. <br /> *#94870345123456789# Deactivate the PWM-Mem. <br /> **21*number# Turn on "All Calls" diverting to the phone number entered. <br /> **61*number# Turn on "No Reply" diverting to the phone number entered . <br /> **67*number# Turn on "On Busy" diverting to the phone number entered . <br /> 12345 This is the default security code . <br /> press and hold # Lets you switch between lines. <br /><b> Author : JBJ<br /></b><span></span>
on Dec 19, 2010 | Cell Phones
Do not have product info need pass key code to link
Many times the code for Bluetooths is simple 4 zeros: 0000
Motivational Quote BELOW from "Weekly Quotes For Staying Motivated": www.dustyspeaks.com/products.htm by Dusty - The DreamWaker! *-* Buy YOUR copy today and stay motivated!
"Failure is only Feedback. Fail FORWARD Faster!" -Dusty *-*
Aug 22, 2010 | Jabra BT4051 Bluetooth Headset
DO YOU NEED BOTH THE COLOR & BLACK INK CAR. TO COPY TYPES INFO
Yes you do.
The printer sinces both color and b/w to operate properly. You have to have both cartridges operational for your printer to work.
Jan 22, 2009 | Fuji M221E E6-120
My camera cannot take pictures.it comes up blank
you may need to release and renew your ipconfig,,,,copy this down:
First,,go to start, then "run" when the little screen comes up,,type in "cmd" all without quotes,,,then a dos screen should show up,,,,in the dos screen,,,,type in: "ipconfig" then you should see all the dos text info on your connection,,,,then type in "ipconfig/release" again no quotes,,,then wait,,you should see all the info fields go into zero's seperated by periods eg: 0.0.0.0.0 etc now type in "ipconfig/renew"
after doing this your internet connection should resett.
If this does not work you need to call up your ISP tech support.
Jan 15, 2009 | Acer Aspire 5100 Notebook
Have just installed (per instructions) a jvc car cd KD-G386/KD-G385 receiver in my caravan, nothing seems to operate, have reset it. and press "display"button-clock comes on for couple of seconds...
Hi colinelva.
I can probably help you but I need more info.
Lets start with the vehicle, What year ,? What specific model?, What type of head unit came out? Was it factory?
Did you use a wiring adapter, or just cut the plug off and hardwire it?. If so give me the color code of all the wires that you used in the dash. are their any left over but not hooked up? How many speakers? All Factory?
I don't need any info about the JVC Head unit.
Lets start with that, and we will take it from there.
Regards, Paul
Jun 13, 2008 | JVC Car Audio & Video
Lexmark Wheelwriter 6 Series II Typewriter Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
