Cannot bring volume down with remote and volume bar keeps climbing up. When Itry to get the menu the menu is always changing.
  • joseph r y couturier Mar 18, 2011
    Its a toshiba hdtv led model 46RV525U.
  • joseph r y couturier Mar 19, 2011
    It sounds logical and thanks, I still would like to know if there is a download on a parts breakdown to make it easier to locate the parts and part numbers. Thanks.
    President:
  • 1,961 Answers
Hi, you did not mention the brand and model of your TV please include also a brief description of it
such as LCD,DLP plasma ,CRT etc. pls post back.
Posted on Mar 18, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Mar 19, 2011
    There are several things to consider in this kind of error on TV.first is
    Mainboard -dust and dirt accumulation on main board results in erratic commands on the system because of an static creates by dust cleaning will solve the problem.use a paint brush to clean the board.
    POWER SUPPLY- If the power supply is not stable will also creates this kind of problem.have a close look at the capacitors on the power supply if there are bulging capacitors replace it.use the same rating and value of capacitors you are replacing.
    CONNECTORS- secure all connectors make sure all connectors are perfectly fits the socket to avoid malfunction on the system.
    RESET- resetting the main board will also fix the problem .at the mainboard there is a main reset button a small button called tapped switch.try pushing this switch while the TV power is on.
    STUCKED UP SWITCH- check the switches on the TV'S panel make sure there are no stucked up switch on it free the switch if you found any.
    good luck I hope I give you the right information you need...LET ME KNOW how it goes!
  • Danilo Baraquiel
    Parts available online can be found from this link. It includes the parts cost.
    http://www.partstore.com/Model/Toshiba/T...
    just choose category of the parts on the left portion of the window to view the parts.
    Good Luck!
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
I have an audiovox dv7300 surround sound. When i turn the device on, the volume automatically climbs up to 50 which is the max. The volume knob will not bring the volume back down and the remote can bring...
1) retight the springs contacts batteries with pliers for a better contacts
2) open the r.control and clean the keypads very well from dirty, oxide, and bad contacts, with contacts cleaner.
3) otherwise you must go to the repair shop TV.
God bless you
Jul 09, 2012 | Televison & Video
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
LG HDTV Volume bar disappeared from Display
try factory reset in main menu or press menu continuaslly until it no longer comes up then 7777 on remote
May 05, 2010 | LG 42LC2D 42 in. LCD HDTV
How do you tune in a alba tv with no remote control
There is no way to tune it, the menus that you need to bring up can only be accessed with the menu buttons on the remote
Feb 28, 2010 | Televison & Video
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
