Question about Whirlpool Refrigerators
I removed the ice storage bin to clear a blockage and the spring popped out of the release button.Where does it go? I can't seem to get it back in the right place. Model #ED2KHAXVL00
  • 3,018 Answers
Here is a picture with the assembly. Note that your does not have a pin on it. It is from section 4-7 at this link just in case you cannot read the printing or see the pic that well.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Posted on Mar 18, 2011
How i replace spring on indoor ice catcher release
If you are asking about the spring on the ice bucket button, you will need to remove the whole lever and fit the spring on while you are reassemble it and slide it back into place.
Dec 17, 2013 | Refrigerators
Can't remove ice storage bin from Kitchenaid side by side
This units are prone to do this. Best way for me to tell you is to work ice bucket side to side. Then shut the freezer door and switch between the cube and crushed ice. Tap the dispenser lever just long enough to engage motor. Basically you are rocking the coupling back and fourth in the auger assembly. Will come loose but may take a bit.
Aug 18, 2012 | KitchenAid (KSRD22FKST) Side by Side...
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
The part where you would press to get ice, well up in side is not releasing the ice and closing back
On mine, using crushed ice will cuase a build up of ice along the shoot. I take off the storage bin and manually open the door cleanining out the shoot. Make sure to check under the removed storage bin before replacing.
Aug 30, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice maker no longer making ice
Remove the ice bin and check the spring on the white cut off arm . When arm is pushed back , it should spring back foreward .Ocassionally , the top portion of the spring pops out of the hole which will be visibly evident . If so , use a small screwdriver to push back in place . If looks ok , then pour about 1/2 cup of water into icemaker and wait to see if it dumps . If dumps , then water valve is bad . If doesn't dump , icemaker is bad .
Jul 19, 2009 | GE GSS25LGM Side by Side Refrigerator
Know how to put the ice bin latch and spring back together
I had the same problem. When you put the spring back on the little arm towards the button, use a mini screwdriver or something to pull the spring back and pop the latch part back in the indented spots. Then, it will seem stuck but you just put some pressure on the curved side of the latch - opposite from the button and it will "pop" back into place.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker sprays water into the ice storage bin
you need to remove the i/m from the freezer and make sure the "fill cup" doesnt have an ice blockage. thats where the water has to funnel into the mold. it can get a drip into the cup and then freeze in the cup. clear it out once and try it again, but if it happens once or twice again , then you might have to replace the water inlet valve.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Doesn't fill up
sounds like the ice is not releasing from the freeze plate before the waterpump comes back on. you can turn off icemaker - dry the plate with a towel - take fine steelwool and go up and down on the tray until all discoloration is removed and the plate is shiney - empty bin - flush plate and bin - turn back on and see if ice falls onto cutting grid either right before or right after waterpump comes on.
Nov 24, 2008 | U-Line Icemaker
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Refrigerators Logo
299 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
