Question about Panasonic Audio Players & Recorders
Hi, I have a Panasonic Blu-Ray Suround System with a Satellite HD box plugged into via optical. On normall channels the surround sound works fine, but when I switch to a HD Channel I get no sound. Any ideas?
  • 90 Answers
Check your sound settings on the satellite box, they might be set to output only to hdmi on hd, or the stereo/surround settings are messed up. If not giving a call to your sat tv provider might help because if it is a common problem they will know about it, and don't forget to do a full restart of the devices, this has worked wonders for me.
Posted on Mar 18, 2011
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
I have an LG HT752 TP home cinema system. I recently bought a Panasonic DMP BD 65 blu ray player and connected to LG system via optic cable. Problem is that when playing blu ray discs on the Panasonic...
That shouldn't happen, what kind of cable are you using? you should try an hdmi cable. its electronic so it either works or doesn't and there shouldn't be any lag at all.
Feb 28, 2011 | Televison & Video
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Surround sound signal not transferring.
need to go into audio menu and select digital audio as the output signal, its probably set to mts stereo.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
44 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
