Question about Sanyo PLC-XU73 LCD Projector
Hello I cannot connect my sanyo projector PLC-XU73 with labtop can anybody help me how to do it? andjust resolution of screen or what
    Problem Solver:
  • 9 Answers
Hello, Here is a step by step process on how to connect a laptop to your projector.
Start with projector and laptop turned off
Attatch all cables required, power and signal (VGA) for both proj and laptop
At the laptop end, ensure that the VGA is securely fastened using the screws attatched to the cable
at the projector you should notice there is more than one socket that the cable can go in, you need to make sure you are connecting to the INPUT not the OUTPUT.
Turn on the projector and allow it to go through it's start up process, once started select the input that you plugged the cable into (usually INPUT 1, PC, or VGA).
Turn on Laptop and wait for it to do it's start up process, log in if needed.
If by now you don't have an image on screen, you'll need to try and change your output arrangement.
THE FOLLOWING IS FOR PC ONLY, NOT MAC
This is very simple, but a bit awkward to explain so bare with me. To do this you need to hold down the 'Fn' key and press the correct F# key, this changes with every brand of laptop, so for instance HP and Compaq is F4, IBM is F7, Toshiba is F5. You may be able to tell just by looking at the symbols on your F# keys. If you don't know which it is you'll have to look it up (I don't know all of them sorry). So if you had a HP laptop you would hold the 'Fn' key and press the 'F4' key.
You should now have an image on your screen, if you have lost the image on your laptop's screen after doing the previous step, press the Fn F# again, and it should send to BOTH screens.
The projector that your using is designed to run a resolution of 1024x768. When the image came up on screen it should have changed it automatically, however if it didn't do this:
right click on your desktop and click on 'properties'
click on the settings tab up the top
under 'screen resolution' you should see a horizontal slide bar move that to 1024x768
Click 'apply'
If a box pops up asking you to confirm the setting click yes quickly or it will revert back.
I hope this helps,
Posted on Mar 25, 2011
I put a new bulb in a sanyo plc-xu73 projector still no light how do i test the bulb to make sure its not bad
There's no test equipment for DLP lamps.
The only way to test the lamp is with a working projector.
I am a Tech many times, I can tell by a visual inspection.
If you purchased a cheap lamp, or from someone beside a Sanyo dealer then, you may have a bad lamp.
www.aaatvservice.com
Jan 26, 2012 | Sanyo PLC-XU73 Multimedia Projector
Where is the thermosensor
These are either located close to the heat-producing part or near the fan exhaust port.
Aug 20, 2010 | Sanyo PLC-XU73 Multimedia Projector
Red vertical lines from top to bottom. Red lines,white lines in a uniform pattern
Try to change your VGA cable if the problem occur your A/V board was deffective.
Oct 23, 2009 | Sanyo PLC-XU73 Multimedia Projector
Laptop is not being connected
THE PIN CONNECTION MAYBE DIFFERENT IN THE OTHER LABTOPS YOU WOULD HAVE CONTACT THE VENDEER AND CHECK THE PIN OUT FOR THAT PORT AND SEE IF THEY ARE THE SAME.
THE COMPUTER CABLE SPACIST CAN HELP YOU, CABLE CONNECTION, CABLE AMERICA, AND CABLES TO GO.
ROD
Feb 17, 2009 | Sanyo PLC-XU73 Multimedia Projector
Macbook compatibilty with Sanyo PLC-XU32 projector
Force the frequency on the mac to 60hz. The projector can't respond to the high clock rate of the mac. Contact sanyo for a firmware upgrade to this product as well
Jan 27, 2009 | Sanyo PLC XU32 Multimedia Projector
Sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Nov 02, 2008 | Sanyo PLC-SW30 Multimedia Projector
Problem with color shift
Hi there
This might be a faulty Mainboard - that will need repair or replacement - and is quite expensive.
First check by using another cable , if the problem still occurs then the above will most probably apply.
Mar 30, 2008 | Sanyo PLC-XU73 Multimedia Projector
Configuration
hello Friend
Connect the RGB Cable of the laptop. Power up the Projector and restart your Laptop. that will automatically run. Or Go to laptop display properties by right clicking the mouse and settings to resolution 800x600 pixels and then check.
Viren
Rave Services India
Feb 07, 2008 | Sanyo PLC-SW30 Multimedia Projector
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
Sanyo PLC-XU73 LCD Projector Logo
166 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
