Question about Frigidaire PLEF398AC Electric Kitchen Range
Fridgidiare oven reads code F1 what does this mean
The oven comes on and gets real hot by itself. The code reads F1. Don't have the manuel to this oven can you help?
  • Anonymous Apr 18, 2009
    F1 IS DRIVING ME CRAZY!!!!!!!!!!! GOES OFF AT ALL TIMES, HELP!!!!!!!!!!!!!!!!
  • 639 Answers
Hi Van,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model #
and download the manual.
But I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
F1-1 reading on control board
F1:-1 may appear on your Gemini oven range for various reasons, but the meaning is always the same. The error means that the display relay control board thinks your temperature on your upper double oven range is running away and getting too hot. To fix the error F1-1, check the wire harness between your oven sensor and your control board to make sure the wires are secure and the connections are good. Pull the oven out and remove the back panel on the oven to check the wires connections. If the connections and wires check good, disconnect the wire connection to the oven sensor and check the resistance of the sensor. The resistance should be 1100 ohm at standard room temperature. If the sensor is not good you need to replace it, and if the sensor checks within range replace the display control board. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 09, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Getting F1 code on my acf4225as Amana big oven
The f1 code code means a button on the touch pad is shorted,you can push clear and the F1 will go off but if it comes on again within 30 minutes the touch pad will need to be replaced
Jul 28, 2011 | Ovens
F1 error apppears and broil comes on extremely hot and will not shut off
HELLO THERE: This is a fairly common problem with these ovens Here is the meaning and what could be wrong with it F1 Element relay circuit failure meaning the temperature sensor for this oven is bad and not allowing the oven to read the temoperature Next your Control board may be bad meaning it is not sending the proper signals to the elements telling them what it is supposed to be doing these are the only 2 things that are the most common problem ok SO i would have both of these parts checked with a meter and check them for continuity if they have high readings this means they are about to fail ok> Hope this is very helpful pleae feel free to post me a comment back and i can explain this a little bit more if needed Furthermore if this is under warranty you can use the warranty to fix this Best regards Mike
Jan 21, 2011 | Ovens
Where can I get a code book for GE troubleshooting of stove. I keep getting a loud beep and a code F 1 appears. What does F1 mean
Hello & Welcome to FixYa
F1 error code in your Kenmore is displayed when the oven temperature sensor goes bad, before replacing this sensor you can check it with a voltmeter. If it reads between 1050-1100ohms then it means that the temperature sensor is fine and the electronic control board needs replacement. However, after reading your question replacing the sensor is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | GE Microwave Ovens
Making a constant beeping sound, F1 blinks and the oven continues to get red hot. Is this something we can get a replacement part for?
F1 error code in your GE is displayed when the oven temperature sensor goes bad, before replacing this sensor you can check it with a voltmeter. If it reads between 1050-1100ohms then it means that the temperature sensor is fine and the electronic control board needs replacement. However, after reading your question replacing the sensor is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Kenmore Kitchen Ranges
The oven beeps and has a error F1
Hello,F1 means Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled,replace the oven control(also called clock or ERC),touch pad,or both.
Thanks
Jun 01, 2010 | GE JTP20 Electric Single Oven
The F1 comes on. The oven will come on by itself and the F1 Sounds.  Does this mean the oven is un-repairable?
F1 is the fault code for a bad EOC (electronic oven controller). The unit can be repaired
clarkco
Feb 19, 2009 | Frigidaire FEF336BC Electric Kitchen Range
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
269 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
