Question about Luhr Jensen Little Chief 9800
Bought little chief model 20 smoker don't know how to use it...
    Sergeant:
  • 176 Answers
The Little Chief smoker, manufactured by Smokehouse, is available in front-loading and top-loading styles. Both models are electric, depending on a 250 W electric heating element to supply the heat. The smokers can accommodate a maximum of 25 lb. of meat or fish. These smokers are for outdoor use only, and plug into a 120 V AC electrical outlet.
  1. Brining
    • For extra flavor, treat your meat, poultry or fish to a brine bath before smoking. Use 1 cup of kosher salt for each gallon of water. Consider adding molasses, spices or even a pureed jalapeno pepper or two into the brine solution. Leave thicker pieces of meat in the brine solution overnight. Fish only need to be soaked in brine for around four hours.
    Wood Chips
    • Mesquite and hickory are probably the two most widely used woods for smoking, but apple and pecan wood can give your smoked foods another tasty dimension. As with anything else, experiment to create your own favorites.
      Smoker wood is sold either as chips or chunks. Use large chunks to smoke thicker pieces of meat; the chips will be spent before they have thoroughly smoked the meat. You can continually replenish the chips, perhaps every half hour, for as long as you wish to smoke the food, but the job can be tedious with a large roast that takes hours to smoke.
      Smoke the wood well before it is introduced to the heat. Chips will be completely soaked in a half hour, but chunks of wood will require an overnight soaking before use.
    Smoking
    • When your meat is thoroughly brined, and the wood soaked, carefully lay out the meat on the smoking racks. Make sure that there is some space between each piece. Place fish on the rack with the skin-side down. Drain your wood and place it into the smoker on top of the heating element. Use the small pot that is provided to keep moisture or collect juices. Place the racks into the smoker and close up the box. Plug in the electrical cord and within about 10 minutes, you should see smoke gently trickling out from the smoker's vents. The thicker the food inside the smoker, the longer the process will take.
    Posted on Mar 18, 2011
      Brigadier General:
    • 4,736 Answers
    Here's a link that will rove to be a wealth of knowledge for you, when comes to using your Little Chef Smoker. Once you've gotten the hang of it, send me a sample of some smoked brisket or some smoked Salmon. I love them both.
    luhr-jensen-chief-smoker.html">http://www.ehow.com/how_7584576_instructions-luhr-jensen-chief-smoker.html
    I need a new electric heating element for my Little Chief smoker
    http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
    Jan 15, 2013 | Grilling
    Need a heating element for little chief smoker model 9800 where do I get one
    Any sporting goods store should be able to provide you with one. In Spokane Washington replacement parts can be found at White Elephant. I had to replace my element and found one there for around 14.00.
    I got mine at Store 2 but am sure that #1 also has them. I have attached a link. In no way am I advertizing a particular store, rather I am giving you a link to someplace I know carries the replacement parts.
    http://www.whiteelephantstores.com/
    Addresses and phone numbers as well as contact info is listed in their website. Good luck.
    Mar 06, 2011 | Luhr Jensen Little Chief 9800
    Big Chief smoker trips 20 amp GFCI
    try to use another out let and see if it is the GFI outlet first if it trip the new outlet then you know it the grill and not the outlet
    Jul 31, 2009 | Luhr Jensen Big Chief 9890
    I have a little chief 9800 top load smoker and lost the heating element in a move. There are two elements available, a 7.5" and an 8.5", but I'm not sure which size my smoker takes. Is there any way to...
    The #4 Little Chief element is 7 inches and more importantly is 250 watts, this is the correct wattage for ALL Little Chief Smokers newer than about 15 - 20 years old.
    The #5 Little Chief element is 8.5 inches and is also 250W but is for newer models before 2006.
    Look at www.smokehouseproducts.com for clarification & best fit.
    For very, very old models (20+) there is a ceramic disk (175W) that heats the chip pan and is hard to find and expensive, a person would be better off finding a new one on sale at the big box boys store
    Jul 07, 2009 | Luhr Jensen Little Chief 9800
    Lil Chief Smoker trips GFI plug
    There is a short somewhere in the unit. Return it ASAP!
    Jun 25, 2009 | Luhr Jensen Little Chief 9800
    Owners manual -download
    You can get this with google.
    Otherwise ask manualfox.com - this is the hassle-less way to get it.
    Jun 02, 2009 | Luhr Jensen Little Chief 9800
    Little chief smoker
    Yes, it can be found at www.smokehouseproducts.com and you will have to look under the recipes tab, it comes in pdf or .doc file forms. They are about 34 pages but I saved mine to disc and reference it without printing the whole book.
    Dec 23, 2008 | Luhr Jensen Little Chief 9800
    Grilling Logo
    628 people viewed this question
    Top Luhr Jensen Grilling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Are you a Luhr Jensen Grilling Expert? Answer questions, earn points and help others
