Question about Dual Presidian DVD Recorder
My PDC3286 remote is not working. I can turn on my DVD player and eject a disc, but none of the other features work. I received a new remote today, thinking that was the problem, but still the features do not work. By features, I mean pause, reverse, slow the speed etc. Any advise.
  • 1 more comment
  • mlsmith_newp Mar 18, 2011
    The disc will play without any problem. I just can not rewind, pause etc.
    I can play the DVD without any problem. Just the other features do not work, rewind, fast forward,
    pause etc.
    I am not sure if you are receiving my answer to your question. DVD works just fine. Just the
    features do not work - rewind, fast forward, pause etc.
    President:
  • 1,961 Answers
May I ask you sir are you able to play a disc to your DVD recorder?or is just you simply turn on and eject the disk and not playing it.because when the disk is not playing then the other function will not have a command on the remote try first lens cleaning do it manually by opening the cover and clean the lens with a cotton buds moistened wit an alcohol gently wipe the lens.let me hear how it goes.
then post back again for further question I'll be glad to give you answers.
Posted on Mar 18, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Mar 19, 2011
    try consulting the playback setting of your player sir.check out if there are playback configuration on the menu.Consider also the format of the disk you are playing.thank you for the reply.
Have sylvania model ld320ssx tvdvr. is there any way we can remove dvr disc without the remote cotrol
I assume you mean the TV/DVD player. There is an Eject button on the front panel of the TV. This is the fourth button from the right. (The power button is the right-most button.) The TV does need to be on to eject the DVD.
I hope this helps.
(note: if you used a mini-disc or have two discs inside the slot, the eject feature won't work.)
Apr 03, 2017 | Sylvania Televison & Video
Tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 | Televison & Video
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
The dvd player tray does not open
# Ensure that any locking feature on the DVD player is disabled.
# Attempt to open the disc tray.
# If the issue is not resolved, turn off the DVD player.
# Unplug the power cord from the electrical outlet for 10 minutes.
# Plug the power cord back into a functional wall outlet.
# If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
good luck!!!!!!!!!!!
Sep 20, 2009 | Toshiba DVD Player
I can't access the DVD features on my Westinghouse vk-40f580d, I put the dvd in and go to the DVD menu, but wont let me use any dvd controlls, it wont on the remote and tv buttons, AND I cant eject, please...
to eject the disc, turn off your TV and hold the eject button then power TV back on. Regarding the DVD feature not working, you may need to change the main board. If your TV is still in warranty, call 1-800-701-0680 for an in home service.
Jul 01, 2009 | Westinghouse Electric VK-40H580D 40 in....
VR357 is froze up
Try resetting the unit.
Press and hold FF and RW on the player (not the remote).
Jan 21, 2009 | Samsung DVD-VR357
Disc Error - Playback Feature not Available on this Disc
I think I figured it out...at least mine is working now anyways and it hasn't worked in 2 years! I got the remote out, pushed setup in dvd mode and initialize and now it works
Sep 15, 2008 | Emerson EWD2004
Televison & Video Logo
62 people viewed this question
Top Dual Televison & Video Experts
Demonic-2011
Demonic-2011
ray gallant
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
