Question about GE WBSR3140DW Top Load Washer
Will not go into spin cycle even when you turn the dial manually
  • 360 Answers
This is a common problem and while it can be caused by a variety of malfunctions the most typical cause is a damaged lid switch. Look for a plastic pin attached to the bottom of the lid near the front opposite the hinges. The pin aligns with an opening in the top rim around the tub, this is where the switch is located. You can attempt to manually actuate the switch by inserting something (preferably non-conductive) like a plastic pen into the opening. This most likely will not work because the switch is probably physically damaged. To repair/replace the switch on most machines the chassis has to be removed for access.
Posted on Mar 18, 2011
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
The Spin Cycle does not work
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Jan 16, 2013 | Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Doesn't spin
  • yes it does sound like the timer is bad.
  • the timer has small contacts in it (sort of like a music box) that lift and rest in certain places.
  • these contacts may not mate properly as the timer goes around slowly in the normal operation.
  •  but when you manually turn it is a faster turn and the contacts will fall faster and get a better connection.
Jun 30, 2008 | Kenmore 23822 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa pye/g2200,3200
when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Oct 20, 2007 | Maytag PAV2300 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
