Question about Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump
I have an older 33 gallon horizontal craftsman compressor. In December I turned the compressor on in my unheated garage when the temp had been in the 20's for days. It seemed to run normally at first. Then after just a short time I heard a loud pop and air leaking under pressure. I immediately shut it off. It sounded like the air line blew but it wasn't the air line. I turned it on yesterday for the first time since then with the temp well above freezing and it ran built and up pressure. But when it reached the threshhold and shut off again I heard the sound of air leaking under pressure. It took 3 or 4 minutes to fully depressure - ize. Can you tell me what the problem could be?
    Problem Solver:
  • 10 Answers
It sounds like the pressure safety valve could be acting up. It is designed to open when the tank pressure it too high and they don't always reset until the pressure is down to nothing. Some models have them included on the gauge manifold and some on the top of the tank under the cover. It is also possible that the upper limit on the motor switch is set a little too high which would also cause the valve to "pop" before the compressor shuts off.
Posted on Mar 21, 2011
Testimonial: "I took the damn thing apart today and sure enough the pressure switch that kills the drive motor was also tripping the small pressure valve on it'ssid"
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman 33 gallons air compressor can only get up to 50 pis. When i first got it the psi go up to 150. I just bought a new pressure switch and it still the same. The motor run none stop and pressure...
hi,
one thing that would be worth checking is the pressure release valve which is usually located on the bottom of the unit. This valve is suppose to be used each time the unit is turned off. For obvious safety reasons you should release the pressure from the tank each time you are done using it. If this valve is leaking or was left open then you will not be able to achieve the desired full pressure. Just checking if this is tight may be your solution! Hope this helps!
Aug 29, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a Craftsman 33 gallon vertical air compressor with reduced noise motor. After not using it for a couple days, it won't start. There is power to the motor. Turned the pulley with power on in both...
The HP is to low for the 33 gallan copasity of the tank 6 hp is not enough If you are trying to run things that draw a large CFM . The disgin of the mechine is incorrect sorry its one mans oppoin the thing can't do what it says it can
Apr 07, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I am changing the belt on a oil less 33 Gallon vertical 1.6 hp Craftsman Compressor and want to know if the bolt that holds the piston rod on is left hand or right hand threads?
This is standard thread, right to tighten and left to loosen.
Make sure to put a small amout of loctite on the threads when you put it back together.
Oct 12, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump Logo
443 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
