Question about Garden
I am stumped. I have a rather large water garden in my back yard, approx 20 x 20 and around 2 1/2ft deep. The pump pushes the water up a slight incline approx 30 yds long to the filter, and the water runs down a "stream" from there back into the pond. When I run the pump over night the water from the pond is almost totally gone the next morning, yet I see no wet areas around the edges of the stream, I have looked carefully at the liner and don't see any holes. The hose from the pump to the filter is partially buried anywhere from 2 to 12 inches deep, but I would think that this much water would show up if it were leaking from the return hose. Same with the receptacle for the filter, it appears to be intact and will hold water overnight. Anyone else ever experienced this and any suggestions? The garden is about 11 years old now.
  • 56 Answers
It sounds very much like a deep slow leak from your garden or in the stream bed. The pump is probably sinking do to its overall weight and vibration when it is running. I would recommend probing the area and look for pooling or mud. If it is a subduction leak it can eventually threaten structures in the area.
Posted on Mar 18, 2011
How many cubic feet of soil do i need to cover 12x15x3x3 garden
you have to many numbers there
If you are saying 12'x15'x what deep 3 inches or 3' ?
12'x15'=180 sq ft x3' = 540 cubic feet or 20 cubic yards
x3inches= 40 cubic feet
May 19, 2015 | Office Equipment & Supplies
My bit in my drill is stuck into a large tree stump... that had been cut close to the ground. How can I get the bit unstuck? My dewalt drill is unable to drill in & drill out.
If it's a twist bit try putting a vice-grip pliers on the end and turn it so the fluting pushes the bit out. If it won't move or if it's a spade bit you'll have to split the wood around the bit. You may or may not be able to do this with the offending part of the stump in the ground. Using a wedge, drive it into the stump near but not next to the bit so you don't damage the bit. Don't drive the wedge flush into the stump or you may get the bit out and then have the wedge stuck. Worst case, carefully use a chainsaw to cut out the stump so you can split the wood around the bit.
Feb 01, 2012 | American Tool 6 each: Irwin Metal Drilling...
Whant to install pea gravel over a grassy spot, and under a bench in my yard. I only need 45 square ft, as the space is 9x5 ft, and I want it an inch deep. thanks
1. Remove the grass in the area
2. Place a border around the edge if desired. You could use wood, but there are several attactive edging materials available.
3. Place black plastic or a weed barrier fabric down on the dirt. the fabric would be best.
4. Place the gravel on top of the barrier to the depth you desire.
5. You will need approx. 4 cubic feet of gravel for 1" or one latrge wheelbarrow load. I suggest you think about 1.5 to 2 inches in depth tho. That will work better in th loing run
Jul 02, 2011 | Garden
I have a very deep yard. Approx. 150 feet from my nearest power outlet. Can I use your weed trimmer products? What is the recommended wire gage of the power cord I should use.
A 16 Ga extension cord will run 10 amps up to oo feet. Electric weed wackers run between 2 and 4 amps, so you should be fine with a 16 Ga cord.
Apr 29, 2011 | Garden
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
I had hit a somewhat hidden stump on the lawn..bending the blade. Took the deck off and replaced the bent blade. Put the deck back on and now the cut seems uneven. It appears that the deck is now...
I've only had luck removeing the deck, turn it upside down. Measure blade, mark, remove blade, insert large pipe over spindle, bend in direction. Re-install blade, and do it all over and over till straight. Measure in several locations.
Aug 18, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
