I have a mastercool cooler. i have tried soaking the intake side of the pads in a clr solution to clean the calcium and other deposits in the past with no luck. new pads each year is expensive. any tricks to get the **** off of them> thank you.
    Brigadier General:
  • 4,736 Answers
You can try soaking them in a solution of 70% White Vinegar and 30% Bottled Distilled Water. At minimum you will have to soak them over night. If it appears the deposits have not cleared out in that time frame, soak them longer and rinse with Distilled Water.
Posted on Mar 18, 2011
Single Control W/ spray Kitchen Faucet
I would try a product called CLR it is for calcium ,lime and rust . then wash it off really well . or put it in distilled white vinegar put.to soak at least overnight .
Feb 02, 2015 | Vacuums
How do you unscrew Hansgrohe showerhead (needs cleaning to remove calcium deposits)?
Easiest is to simply pour some CLR cleaner (from grocery or hardware store, it is a brand name) into a plastic bag, and tie the bag around the pipe with the shower head soaking in the solution.
Easy fix!
Jul 26, 2014 | Hansgrohe Home
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
I have a mastercool cooler and i need to clean the pads. in the past i have tried soaking in a clr solution but it dont help. any tricks to do this would be great. the calcium and other deposits just stay...
CLEANING PADS
My pads are 3 years old. (1) I tried soaking them in Vinegar & water which helped. (2) I then sprayed them with a hose nozzle, that helped also. We live in AZ so the dust storms can be horrendous and I still had build up. (3) So I took a variable speed drill and a wire brush and removed more. (4) Then ,as these filters are made of a wood by product, I took a belt sander ...they look good now. (5) Now when I reinstall them I am going to change the pads so pads facing outside will be facing inside, keeping the 45 degree forward and down. This last step I haven't tried, but it should work.
Mar 18, 2011 | Mastercool 67471 Evaporative Cooler Air...
I am a single woman trying to prepare my mastercool for winter. I don't know how to remove the pads, so if insructions could be sent, it would be greatly appreciated. I don't know the size of the cooler,...
Is it a side draft or downdraft cooler? My instructions simply say to cover the unit, disconnect the power and drain the water for winter. They don't suggest removing or cleaning the pads until spring. If you're ductwork also is connected to your furnace, and you don't have a cookie sheet(piece of sheet metal that fits in a slot beneath mastercool unit or along the inside if it's a side draft cooler) then besides covering the entire unit you cn probably cover the blower, also called the squirrel cage, with a canvas cover.
Oct 09, 2010 | Mastercool 67680 Evaporative Cooler Air...
Bought used - want to prevent rusting of water trough and other
If you can get to the whole water trough to coat it, I recommend you get some spray undercoating or a product like "Phil Swift" promotes on TV and spray it on the affected area.
Mar 29, 2017 | Mastercool 67680 Evaporative Cooler Air...
How do you remove cloudy film from glassware
Hi- try a product called calcium/lime/rust, or CLR. Let glasses soak in sink with warm water and CLR.Then handwash/dry.-- Try air dry option on dishwasher.- heat 'bakes' on mineral deposits from water.Let me know if this helps- ED
Mar 01, 2010 | Dishwashers
What do I use to clean the calcium deposits in the ice maker? The note inside the machine says to use a bottle of Nickel safe ice machine cleaner by Nu Calgon.....Home Depot doesn't have it....Target...
CLR will work great, just rinse the ice maker very well after cleaning the calcium deposits and throw out the first few batches or bins of ice produced after the cleaning process. Good luck !
Nov 26, 2009 | GE Monogram ZDI15C Automatic Icemaker
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
How can I clean the metal grid in the humidifier?
the most practical solution is install a new evaporative pad every year. But if you would like to squeeze "a little" extra life out of the pad . Try soaking it in a solution of 1 part white vinegar to 2 parts water.
Mar 28, 2009 | Honeywell Humidifiers
Heating & Cooling Logo
145 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
