Question about Kitchen Ranges
The lights and fan have quit working. Power to the hood has been confirmed.
  • Kitchen Ranges Master
  • 43,501 Answers
Many times this is because the fuse is blown...the fuses are at many different places...to find it follow the wires after they enter the range hood till you find the fuse...replace with the same fuse amperage and type...
heatman101
Posted on May 09, 2011
My hood fan quit working on my kenmore microwave/ hood combo. How do I fix?
Check to see if fan is getting power. If it is and the fan does not turn then you need to replace that motor. Also check motor bearings - not uncommon for them to get all gunked up with yuck from the air they push through the hood.
Aug 23, 2017 | Kenmore Microwave Ovens
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Jul 29, 2013 | Kitchen Ranges
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
Cruise control quit working
Start with the fuse and if fuse is not blown check to make sure the CC circuit is actually turning on (cruise light when you arm the system) this will confirm you have power. If none of that backtrack to see where power stops. The CC is normally a vacuum controlled system so check under the hood an look for loose or disconnected vacuum lines to the CC unit.
Nov 10, 2011 | 2001 Mercury Grand Marquis
Hi. Last Friday we had a new Kenmore stainless steel range hood installed along with a new range. Yesterday the range hood fan and lights would not work. The fan does not come on at any speed. The lights...
Some installers plug the fan/light into an outlet in the cupboard above. Check to see if that has power. Some of the outlets are behind a panel in the cabinet above and you have to remove the screws. I have seen the plugs laying in the cabinet just like they had never been plugged in. Yours obviously was plugged in but maybe fell out. If the fan/light is hard wired than you should make sure the power is turned off at the breaker box and then check the wiring inside the box to make sure it is wire nutted together and is holding. I would also check that the breaker for the fan/light is still putting out power. These last two might be a little tricky if you have never tried them. The breakers sometimes go bad but look like they are set. If the whole hood fan is not getting power it is probably time for an electrician or the people who installed to come back.
Aug 25, 2010 | Kenmore 52153 Stainless Steel Kitchen Hood
Suddenly the light and the fan quit . Is there a reset
the only "reset" is the circuit breaker.... if they both suddenly quit working, there is no power to the hood at all.... if the breaker/fuse at the box is good, then the hot wire has slipped out of the connection.... not an easy way to trace it. all you can do is work backwards, starting at the power box up inside the hood. if all those connections are tight (power supply to unit's wires) then it's in the wall, attic, or under the floor.... no fun.
Nov 26, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Nutone range hood fan motor quit
You can remove it and bench test it by applying 120 volts to the fan leads. Do you know how to do this -- it can be dangerous if not done properly.
You can also use a voltmeter to measure resistance and check continuity of the motor coils.
May 07, 2009 | Broan-NuTone Intermediate Whispaire ...
No power to heater & AC unit
There is a resistor block in the heat duct that controls fan speed usually when these go out the fan will quit on one speed but work on others until finally all speeds quit,also there is a relay that powers the fan it is under the hood in the relay box
Mar 08, 2009 | 2002 Jeep Grand Cherokee
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Kitchen Ranges Logo
392 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
