I have 52" rca/ge itc
    President:
  • 1,961 Answers
Replace the 2 convergence STK IC BEFORE replacing the IC make sure that all the pico resistor are not open check the resistance with an multimeter replace any open reading resistor.replace also all bulging capacitors on the convergence section...good luck let me hear how it goes.
Posted on Mar 18, 2011
GE D52GW12 HDTV CHASSIS ITC222
The model indicated does NOT use a chip for convergence output; the convergence circuit is divided across three circuit boards.
Does the convergence option appear in the menu or NOT?
Dec 06, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Power light blinks but will not turn on
The ge d52gw12 is a ge version of an rca itc 222. i have worked on hundreds of these at the shop and found with the ge modle 95 percent of the time it is a bad flyback transformer and a shorted horizontal output transistor. While there can be any number of things at fault. This is the first thing to check in this model. At our shop this repair averages 100 to 150 to repair. this varies depending on your location.
Mar 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
When I turn on tv...green light goes on with a squeaky noise and then goes out...no picture and tv does not turn on
a noise like you describe is a symptom of what is known as the horizontal output transistor. It would be shorted and along with that the flyback transformer is bad. the flyback is very common problem with the ge version of the rca itc 222 chasis. This repair generally runs 80 to 150 dollars to repair at your local tv shop.. well maybe at our shop but that an average.
Feb 19, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I cant find where to go to find the convergence option.. the manuel say's its under setup but on my tv thats not an option as it states in the pic can anyone tell me how to get in to convergence threw my...
That's a common problem with that model the auto convergence option would disappear from the setup menu. But it's a very easy and inexpensive repair that you can do yourself. You can get the RCA repair kit called the ITC 222 and ITC 222 A chassis convergence option missing repair kit. The kit contains the FL 231, DL 231, CL 030 and also has repair instructions on CD. Is $25 from www.tvrepairworld.com listed under their RCA repair kit category.
Jan 07, 2011 | RCA Televison & Video
RCA D52W14 Cable connector on the ITC 222 and ITC 222A signal
a good experienced tech might be able to do it for you .  other than that you will have to replace the SSB
Jul 28, 2010 | RCA D52W19 52" Rear Projection Television
The power is out
Replace the deflection board or power board. www.tvrepairworld.com has the parts for the RCA/ GE itc 222 series TVs. You ccan also call them and they will assist you in determining which one you require.
Jan 13, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Rca r52wh74 looks like i am watching 3-d. red, blue ghost lines and picture looks stretched out
The ITC 222 convergence option missing repair kit available at www.tvrepairworld.com usually will fix that issue. The kit contains the parts and CD with instructions
Sep 24, 2009 | RCA R52WH73 Projection Television
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
oki this is an itc 222 or rca hd 52.... if your convergence option is not availvble in your menu and you have a bowed multicolored 3 d ish picture then this points to a special fuse fl231 if you can get this fuse and can solder then it should cost you about 5 bucks and 30 minutes to fix...ill give you more intstruction on how to do this repair. whats your model of your tv]
May 23, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
