Question about SimpleTech STORAGE, SIMPLETECH 500GB PIN COMBO 500 GB USB Hard Drive
Can't detect my drive
When I turn on my drive the blue ring in the middle flashes, then a red light flashes nine times. The USB cable during this whole process does not light up. I have tried a new USB cable and that does not work either. The computer does not detect the drive. What could be the problem?
  • audra08 Aug 02, 2008
    Thank you, but that didn't work, please tell me there is another solution. : (
    I just want to get it going long enough to transfer my files to another drive.
    No clue. It was working one day I had it put up for about a week, plugged it in and now it won't work.
    Problem Solver:
  • 6 Answers
It could need a power adapter if it cannot draw enough from your usb port. I would try another port on the back of your PC.
Posted on Aug 02, 2008
  • qbutcher Aug 02, 2008
    If you're just looking to recover files you can buy a combo sata/ide/laptop ide hard drive to usb adapter. They run about $20 to $40 but can be used for copy files from any drive in the future. The board on your external hard drive could have gone out. What caused the drive to stop working?
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
My Transcend StoreJet 500GB harddisk is not being detected on my Mac. The blue light keeps flashing.
If you are using the USB "Y" cable that has two male ends on one side then ditch it and try a regular usb cable. Regular being a cable that is USB to USB mini, one that as short as possible e.g. 36 inches or less. This solution is what solved my problem, so simple :)
May 30, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
I was getting nine flashes and know the green crt
Sounds like a bad green crt. These Sonys are bad about that.
Jul 06, 2009 | Sony KP-65WS500 65" Rear Projection...
Drive case flashes
The first thing you need to do is figure out if it is the Hard Drive itself or the enclosure.
The best way to do that is remove it from the enclosure & test it either in a PC directly or in another enclosure. If it works, then you can test the enclosure by inserting another Hard Drive & testing it. This should tell you which component is bad.
May 14, 2009 | Thermaltake Silver River 3.5" Encl Silver ...
Pinnacle Video Transfer: at REC, all lights turn red--except USB
how about deleting all the software of that device and reinstalling it as a new device.
the program may have corrupted the flash drive and all the data that is on it and when you pluged into any other device it may of worked a few time but that it will start corrupting everything you have plugin your flash drive into.
you are going to reformat the flash drive and re install any type of drivers for the flash drive and check every where you have used the flash drive has not corrupt any of the systems you are using.
let hope we got it before you loose your intire system due to corrupted software downloads or uploads to flash drive and computer system and this may include a network if you are on one.
rod
Feb 27, 2009 | Pinnacle Video Transfer
Simpletech 500G HD
that means system wont support the drive or you are having problem with the detection or driver.
some system wont detect the drive with large size without drivers.
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech STORAGE, SIMPLETECH 500GB PIN COMBO 500 GB USB Hard Drive Logo
278 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
