Question about Marantz Audio Players & Recorders
I am only able to get sound from one channel when I plug in an external devise (Ipod) into any RCA jack. This was not always the case. Any ideas?
    Brigadier General:
  • 8,546 Answers
Do your other analog sources still work okay? FM? Test tones?
You don't name the model so I can't name specific controls.
If it affects all analog sources there is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Posted on Mar 18, 2011
Please provide instructions for how to play music from I phone/IPOD using analog. I plugged in the devise into the Video 4 area in lower right hand corner.
Hi Kathy, the easiest way to do this on your txsr700 would be for you to purchase Y connector which will have RCA connections on one end and a headphone jack on the other end. Connect the RCA cables to any open RCA connection other than the Phono input and then connect the headphone jack to the iPod. Please be sure that the volume is turned up a bit on the iPod. If you should require further assistance please feel free to contact our Product Support Team at 800-229-1687, Thanks, JT
Aug 23, 2015 | Onkyo TX-SR700 Receiver
How do I get operating instructions for this sound bar
1. Plug it into a power outlet and turn it on.
2. Put 2 AAA batteries in the remote control.
3. Dock your iPod or iPhone into the docking connector.
4. You can hook up the sound bar to your PC (from the RCA(L/R) audio output on your TV to the RCA audio input on the bar) or to your PC (from the headphone jack on the PC to the LINE IN jack on the bar). Obviously, you can hook it up to both TV AND PC only if those two are located close to each other.
5. Using the remote, select the audio source/input you want to listen to: iPod/iPhone, FM Radio (an FM tuner is built into the sound bar), TV or PC.
Hope this helps.
Dec 20, 2014 | Apple Ilive Itp100b 2-channel Speaker With...
No right channel on AV2
First, does TV sound without external sources work on both channels?
With the one RCA connected and getting sound, unplug it and plug into other channel. Any sound? If not, remove it and plug the other RCA by itself into the left channel. Sound? If yes, plug it into the right channel. No sound? If not, bad TV input.
If you do get sound on that other channel with a single RCA, then you have either a bad cable or bad source. Reverse RCA's on source and try same test, plugging each RCA into each input on TV one at a time.
If the TV is bad, you will get sound on just the left channel regardless of which RCA you use.
Dec 16, 2013 | Blaupunkt Car Audio & Video
How to hook up speakers to an ipod dock
Just run an cable (3.5mm headphone jack into stereo rca cable) from your ipod's earphone jack to one of the available input channels on your amplifier. I put mine into the front auxiliary input on my amp and just simply selected that channel on the amp. Hope it helps. By the way, an RCA cable is the one with the white and red plugs. 2_21_2014_8_49_22_pm.png
Sep 14, 2013 | Audio Players & Recorders
Will this receiver accomodate an iPod player? Thanks, Byron Nimocks
It may not take the iPod directly if it doesn't have a dock built in, but you can always connect the iPod to an available input with a suitable cable. You'll need a cable with a plug to fit the iPod headphone jack (a 1/8-inch stereo plug) at one end, and probably RCA plugs at the receiver end. Radio Shack sells one so you can see what you're looking for. If you have an iPod dock, they often have audio output jacks for connecting to your receiver. You may need a cable with RCA plugs on both ends.
Aug 07, 2011 | Integra DTR-5.1 Receiver
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
I want to connect my ipod to the aux inputs on back of unit
Hello gcd_sun,
The RCA jacks on the back of the Pioneer DEH-1500 are preamp outputs, not inputs. They are to connect an external amplifier for additional speakers or subwoofers.
The output from your iPod is probably "bleeding over" into the receiver detector stage. When the antenna is disconnected, the signal passes into the amp by itself. Connecting the antenna provides enough signal so that both are amplified.
To connect the iPod, you need to purchase a wireless iPod adapter, or a new head unit that includes an "AUX" input or a dedicated adapter for the iPod.
Hope this helps.
Sep 10, 2009 | Pioneer DEH-1500 CD Player
Haveing trouble hearing sound when I have my IPod connected
You need a AI Net cable or Speed Cable... It plugs into the back of the radio (looks like a circle with holes), and the other end can have a "Y" plug (headphone jack and iPod flat jack). The headphone jack for sound, the flat jack to charge he iPod while listening. I just bought mine on Crutchfield.com for $29.99. With the discount code: 3A156 you can get standard shipping free. The item # is: 127ICALPA and it's named "PAC iPod Adapter for Alpine".
Mar 14, 2009 | Alpine CDA-9833 CD Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
48 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
