Question about Car Audio & Video
I have an astra 1.6 sxi on a y plate, the other day it ran ok then would not start when went to start it, it turns over fuel is getting to the injectors and has a great spark, its had a new crank sensor what else could it be?
  • 22,326 Answers
Well if this code thing could be unravelled then i might be able to help but i do not what year it is ,what is a Y plate is this something to do with the chassis number or what?? Before you go any further check the timing belt and if ok then try the spare key incase the chip has fallen out ,anyway ice road truckers is on sky so iam off
Posted on Mar 18, 2011
Battery changed in key fob now will not start
You have lost programming, contact your local dealer.
Jan 18, 2017 | Cars & Trucks
Vauxhall astra 1.6 sxi wont start
Great AA's you have!
Have you checked that you REALLY getting sparks on ignition while starting engine?
Jan 22, 2018 | Cars & Trucks
O2 lincoln ls check engine light & fuel gauge went to empty the next day it wouldny start replaced fuel pump & fuel gauge ran fine drove about 40 miles the next day started it up check engine light...
You have two pumps,I guess you know that ,if you already did one. Did you check fuel pressure at the rail and check out the electronic pressure regulator? What codes are coming up and do they stay set?
Feb 05, 2010 | 2002 Lincoln LS
2002 Astra SXi and engine management light on with lack of power
Keep always half of tank, could be pick up all garbage. can damage fuel pump.
May 15, 2017 | 2004 Toyota RAV4
Engine cranks but won't start
I firstly would check relay. You can use an ohmmeter to check the resistance of the relay. If you get a reading, it is good, If not it is bad. Than disconnect fuel pump wire harness and do the same.
May 28, 2009 | 1991 Chevrolet S-10
2000 chevy surburban 1500 will crank but no start. waited one day then started. Ran for a week. Stopped again. Waited one day no start. Waited three days started again. Any suggestions??
more than likely your fuel pump went out. it's in the tank. you can try spraying carb cleaner in your throttle body and have someone crank it. spray small amount of carb cleaner beware of backfire. do not acclerate while cranking. if vehicle turns on its your fuel pump
May 05, 2009 | 1999 Chevrolet Suburban
If it is an electrical Fuel Pump, you will hear the pump whirring as soon as you turn the key to "ON". If you can't hear it, the fuel pump is bad. If it is a mechanical fuel pump on the engine, remove the hose that goes into the carburator. And crank the engine. It should pump the gas out without a problem. If it does not, the fuel pump is bad. Also check the relay to the fuel pump and the shutoff valve. It is more likely that it is a relay problem since it hits a bump and goes off then it carries a current again. Probably a bad relay under the hood for the fuel system.
Apr 08, 2009 | 1991 Chevrolet S-10
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
