Question about Uniden BC350C Base Scanner
Scan with out showing b3 found - Uniden BC350C Base Scanner
I have a intel core 2 duo processor can i buy intel DH67VR-B3 motherboard can both procesor and mothrboard b compatible? plz help immediately
i found the product guide for DH67VR i'm not sure if that covers the last 2 characters in the model, however they say this under processor:
Intel Core i7, Intel Core i5, Intel Core i3, and
Intel Pentium processors in an LGA1155 socket:
So I don't think that motherboard will work with that processor, unless the -B3 version of this model has a different socket some intel core 2 duo processors have these socket types: PLGA775, PBGA479, PPGA478, So I would need more information about your processor also. but none of the intel core 2 duo processors seem to fit that motherboard socket.
http://downloadmirror.intel.com/19793/eng/DH67VR_ProductGuide01_English.pdf
May 21, 2012 | Intel Computers & Internet
The graphics card along with all the other components are in, and when i fire up the computer the monitor gets a signal from the graphics card but nothing comes up on the screen. We tried 3 different...
Hi, try to look in the bios settings for fault.
The PCI-E settings are maybe wrong
You can download a manual here:
http://www.msi.com/product/mb/P67A-C43--B3-.html#?div=Manual
It should be able to show you how you do that.
Here you also find drivers.
Hope this was helpfull.
Aug 14, 2011 | MSI P67aC43 B3 Lga1155 Intel P67 B3 Ddr3...
Service code B3 shows on dashboard, what does this mean?
Honda has different service package reminders programmed in the computer. Contact your local dealer or your owners manual. B3 will be an oil change and probably some other fluid checks or changes.
Dec 05, 2010 | 2005 Honda Odyssey
In 3 buckets, two Buckets filled with 20 litres of water, first- 19 litres capacity(max) second- 13 litres capacity(max)-Filled third- 7 litres capacity(max) -Filled i need to fill 2 buckets with 10...
Assume the following:
B1 = 19 litres capacity
B2 = 13 litres capacity
B3 = 7 litres capacity
B2 and B3 are full. The answer is:
1. Pour 2 litres from B3 to B1
2. Pour 8 litres from B2 to B1
3. Pour the remaining 5 litres in B3 to B2
Another answer:
1. Pour 10 litres from B2 to B1
2. Pour 7 litres from B3 to B2
In both answers you will get 10 litres in two buckets.
Rate if this answer was helpful.
Thanks
Oct 22, 2010 | Computers & Internet
I need a new watch band for my Nixon Scout watch
Try contacting a Nixon service center.
You can locate your nearest service center by going to their web site "www.nixonnow.com/dealers/" and filling in your details.
Mar 02, 2010 | Watches
EUROVOX NOT SHOWING PIC
**UPDATED 7th May 2009*
These are what I've been told are the latest codes.
C/W 5c-01 May 7th 2009
key 00 = A7 B2 EE 5F 9D D8 69 0E
key 01 = 3D 82 E6 58 8E 0D B3 62
T/W 5a-01 May 7th 2009
key 00 = AA B7 D1 D9 CE 8E 83 AF
key 01 = 8E 80 D7 EF 44 93 02 2B
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
IRELAND NTL 54-01
KEY 00 =B0 B8 4F 04 E6 5F 87 80
KEY 01 =A3 EB EC 07 D6 49 D2 EB
IRELAND CHORUS 5E-01
KEY 00 =CE 19 2E 87 80 61 74 90
KEY 01 =62 FA D9 F3 CE 05 FA 79
May 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Service due soon code B3
Hi,welcome to fix ya.
that means you need an oil change ,tire rotation, air filter and cabin filter.
Mar 24, 2009 | 2004 Acura TL
Daily Payroll Time Sheet Calculation
=IF(C3-B3>6,(C3-B3-1)*24,(C3-B3)*24)
Is this what you want ???
B3 has start, C3 has end, formula is in D3
Aug 12, 2008 | Toshiba Satellite A100-S8111TD Notebook
Formulas
You may want COUNTIF if you're specifying criteria. For instance, if my prices are found in b3 to b7, here's a formula that will find all those that are less than 6 ($6.00):
=COUNTIF(B3:B7, "<6")
If you're using multiple criteria, such as you want to find all the prices that are greater than $5 and less than $8, the following will accomplish it. (The ABS gives you the absolute value of the result, in case the smaller number is first.)
=ABS(SUM(COUNTIF(B3:B7, ">5") - COUNTIF(B3:B7, "<8")))
Nov 06, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Uniden BC350C Base Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
