Question about Bosch Dishwashers
When we set the dishwasher to run, the timer never counts down, and it sounds different than it used to
  • 77 Answers
Electric smell bosch dishwasher
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
Apr 16, 2013 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher control panel problem?
what is your model number is then we can get started then
Jan 04, 2013 | Dishwashers
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
HI I HAVE A GREAT ILIVE INTERGRATED DISH WASHER, BUT NO MATTER WHAT SETTING I PUT IT ON TO WASH IT WASHES FOR 88 MINS, IT DID NOT COME WITH A BOOK AS IT WAS LAST ONE ON SALE CAN YOU HELP WHAT DO I HAVE TO...
Is your display faulty?
Does the timer count down?
Does the run time of the dishwasher change even though 88mins is displayed?
if all else fails run the dishwasher from a plug in timer, turning it off after 25 mins :-0
Dec 17, 2010 | Dishwashers
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Washer keeps spinning water and not moving on to the next cycle
Sounds like the timer has gone bad and is not letting anything work. Washers, dryers and dishwashers have a timer that you set at the start and then the system counts down off of that. If that stops working it will run forever
Feb 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
MDB7100AWB STOPS AFTER 3 SECONDS OF RUNNING
1. The Maytag sevice centers, if close, are "great". You describe the problem and they supply the part. If far still give them a call.
2. The problem is probably the control. It's a simple fix. Just replace the part. And you can order the part from the service center. Takes 10 minutes.
Tango
Feb 09, 2008 | Maytag MDB7100AWB Dishwasher
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
155 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
