Question about Technics Audio Players & Recorders
Have a SL D3. Pitch adjustment is sticky. Cannot control pitch.
djproaudio
  • 515 Answers
SOURCE: Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Posted on Dec 03, 2007
djproaudio
  • 515 Answers
SOURCE: technics 1200sl pitch control
There seems to be 2 issues with this unit. Usually when the platter speeds up very quickly, one of the IC (integrated circuits) are faulty and needs to be replaced. However, I've never seen the 33/45 lights come on in addition. So, perhaps the issue started with faulty 33/45 switches, and it then caused a short to one of the IC's.
This will have to be professionally serviced, as it is not an easy fix. There are various circuits on the main board which control the drive, so it's a matter of diagnosing which is the culprit. The 33/45 switches will also need to be tested/replaced.
- TERMiNAL OPTiC
www.DJPROLAB.com
Posted on Apr 30, 2008
  • 5 Answers
SOURCE: SL-1200 MK2 Tone Arm Oxidized and Height Adjust
EXCUSE ME! PLEASE FORGIVE YOURS TRULY!!. I mis stated something. Vinegar NOT mineral oil to clean the oxidation. You are correct in the type lubrication. A dry-teflon is best in this application. A minor adjustment in the balance of the arm may be needed. Any chemical used on electronic ckts other than the one that replaced the freon type could be harmfull but any lube used directly on the mechnanics is welcome. You may choose a syringe to apply the small amount in exactly the point of need. This is a well known procedure in the medical field on laboratory equipt.
Posted on Sep 18, 2008
  • 104 Answers
SOURCE: Speed is inconsistent
if it does not brag about being "direct drive" on the front of the unit, then it is probably belt driven
http://www.archive.org/details/Turntable_Belt_Installation
will help you remove the platter to check the belt. if it is slipping it is the most likely cause.
Posted on Feb 16, 2009
  • 489 Answers
SOURCE: Want to know how to most properly operate a Marantz TT530 direct drive turntable. Particularly how to adjust the pitch control. Thanks
i sent mail them  they sent me this.  they gave me adress in my country and try to mail them and ask thier shop in your country or city. pls rate this.
Thank you for your message.
Unfortunately, this device is too old and we are not keeping archive for a so long time.
Try to contact our distributor in Turkey who will perhaps be able to help you:
ERTEKIN
ELECTRONIK TIC VE SAN A.S
GALIP DEDE CAD NO 113-115
80020 KARAKOY
ISTANBUL
Telephone: 90 212 293 93 90
Fax: 90 212 249 3512
E-Mail: ertekin@ertekin.com.tr
WWW: www.ertekin.com.tr
Regards,
Philippe Hautemaison
D&M Professional
T: +33 (0) 141 38 32 50
F: +33 (0) 141 38 01 10
-----Message d'origine-----
De : EN CONTACT FORM [mailto:info@dm-pro.eu]
Envoyé : jeudi 28 mai 2009 20:51
à : info
Objet : D&M Pro website Enquiry | Marantz Fully Automatic Direct Drive TT530
Address: istanbul
Town:   istanbul/turkey
E-Mail: ametehan@gmail.com
Phone:  +905059674232
Subject: Marantz Fully Automatic Direct Drive TT530
Message:
i need manuel of Marantz Fully Automatic Direct Drive TT530
where i can find ? i tried your website  i didnt find. can you help me ?
This message has been generated by the contact form on dm-pro.eu | 05-28-2009 07:50:36 PM
Posted on May 29, 2009
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
Pitch light pulsates when i press start
the pitch adjuster is supposed to blink that is how you adjust the pitch. hope i understood your question right.
Jun 15, 2012 | Panasonic Technics SL-1200MK2 Turntable
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
How to calibrate control on a technic 1200 by sight
Put the pitch slider to +6 and adjust the internal preset until the top set of dots on the platter are stationary.
Check again with the pitch at +3.3 if the dots are stationary then job done!, if not then the pitch slider is worn and perfect calibration won't be possible until the pitch slider is replaced.
http://stores.ebay.co.uk/methleykev
Jul 14, 2010 | Technics SL-1200 Turntable
When using my pitch controll the spped does not
the pitch control slide potentiometer needs to be replaced. This is a common failure on the sl-1200 series.
Apr 22, 2010 | Technics SL-1210M5G Turntable
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Jul 20, 2009 | Technics SL-1200MK5 Turntable
After mixing for a while the turntable (1200 technics mk5) starts to lose the pitch or the record starts jerking up near the -5 or -6.
hi! there is a problem inside your turntable (on the main board) check the components  TRANSISTOR    Q2, Q3,  ZENER DIODE   D3..
CHANGE IT IF POSSIBLE..
Jun 14, 2009 | Technics SL-1200MK5 Turntable
Stiff Pitch Adjustment
What did you open up? The top of what? If you could be specific, I can direct you.
If your pitch is stiff, try spraying some contact cleaner or similar - DO NOT USE WD40. Use an electrical contact cleaning solution, such as CAIG DEOXIT or CAIG FADERLUBE both work very well, and are good for electronic contacts.
If this does not work, then maybe the pitch control knob/shaft is slightly bent? Any physical damage?
Other than that, there isn't a whole lot you can do, unless you replace the pitch control - Technics Pitch Control.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 14, 2009 | Technics SL-1210M5G Turntable
Panasonic automatic turntable model sl-hm42
I'm having a similar issue - except my panasonic sl-hm42 platter is moving too slow on 33 1/3 settings (don't have any 45's to try). It's a DC model, so I would think there would be some kind of pitch control settings or screws somewhere on it but I can't seem to find them.
Does anyone know if it's possible to adjust the pitch on this model turntable? Thank you!
Oct 25, 2008 | Panasonic Technics SL-DZ1200 Turntable
Broken pitch control
Yep, time to replace the pitch control. You can attempt to do this yourself, however good soldering skills are required (not the time to learn). You will have to desolder the old pitch control, and solder on the new one. Which is why I say, now is not the time to practice soldering on your turntable. You could actually cause more damage.
If after replacing the pitch control, you still have the same issue, then there is something wrong with the drive on the unit. The drive is controlled by various integrated circuits (IC's), and they are known to short out every now and then. The problem is isolating the correct IC. FYI, Technics is starting to discontinue parts, and 1 of the main IC's on this unit is no longer available (IC302 - Nand Gate).
You can order the PITCH CONTROL HERE.
DJ PRO LAB
www.DJPROLAB.com
Apr 06, 2008 | Technics SL-1210 Turntable
125 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
