Question about Sony Ericsson Walkman W595 Cell Phone
Battery is not charging but its as if it is on the front face display
  • 35 Answers
How do you know the battery is not charging? I'm assuming you mean it charges according to the display, but when you disconnect the battery life is very brief. This would be indicative either of a defective battery or power supply.
Try changing the battery, this may rectify.
I hope this helps.
Posted on Mar 18, 2011
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
I have a powerware 9120 and had to replace batteries, unfortunately I had a blonde moment and didnt take note of how the 3 batteries were connected, so my question is are they all connected together with...
Batteries are connected in series on your PW9120-1000. Connect the battery farthest from the end that faces the front display of the UPS with the incoming red wire to the red terminal on that battery. Connect the short cable from the black terminal on on that battery to the red terminal on the next battery (these batteries will face each other, but one set of terminals will be at the top and the other set will be at the bottom). Connect the longer wire from the black terminal of the second battery to the red terminal of the last battery (which will face opposite the 2nd battery). The black terminal on the last battery will connect to the thick black wiring coming in from the rear of the battery case.
Feb 03, 2011 | Powerware 9120 UPS System
Dear Sir, i have 435f if on the player its come walkman symbol and suddenly offff,,,,,,,,,,,
Try charging the battery. To do this, connect one end of the USB cable to the walkman (make sure the w. symbol is facing up), and the other end to your PC. To get a full charge, it will take approximately 4 hours and when it's done, you will see a battery indicator displaying "Full" on the battery. It maybe also that your battery life is used up. You get a certain number of charges (500)before your battery is used up. If that's the problem, you will have to get a new battery. Reply to this solution if this doesn't help.
Nov 27, 2010 | Sony Walkman NWZ-E435F Digital Media...
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Wont charge battery
Take the battery to any auto zone or similar store and have it tested first. If the battery is good and yur bike won't charge it then the charging system of your bike is the problem and will require service.
Aug 07, 2009 | 1989 Honda GL 1500 Gold Wing
BATTERY DIED (INTERIOR LIGHTS) NOW RADIO WILL NOT TURN ON
try either pushing the reset switch, which is usually a small unmarked indentation about the size of a pencil tip on the front of the face or on the subpanel behind the face, or disconnect the battery for about ten minutes or so.
Jul 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
GARMIN STREET PILOT C330
take off the front face plate. hit the reset button on the right. charge it. I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
Feb 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Sony Ericsson Walkman W595 Cell Phone Logo
103 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
