I don't think so. If it's fitted correctly it should not come loose. It sounds like you need a new cartridge. Sadly they do break. But if you get the same type you will have a spare stylus.
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Hello
The turntable bests cannot be rethreaded. It should be replaced with same size. Just go with the broken or loosen belt to any electronic spare part selling shops; from where you can buy the exact size belt. It wont cost more. Keep the present belt with you as sample. OK.
Lift the platter off the turntable. You can identify the
motor spindle by using your fingers to turn the round shaft which rotates
freely. Remove the rubber mat off the platter. Place the belt around the outside
of the drum on the bottom of the platter.From the top of the platter, place your finger in one of the platter
holes and tension the belt so it will not fall off or twist. Griping the
platter trough the holes while keeping tension on the belt place the platter on
the turntable aligning your finger with the belt to the motor spindle.Place the section of the belt on your finger over
the motor spindle. Replace the rubber mat on the platter.
Just needs a new belt. You can get those at audio shops. Just take the table off and take a look at the belt size (should say) or take the belt to an audio shop and they can find the size.
There are zillions of belts out there. I hope you still have the broken one which will give you the profile of a new belt. Measure the diameter of the sub-platter under the platter. The belt you need well be a slight stretch fit. Then, with the platter back in place, slip the belt over the motor pulley making sure it is not twisted.
