Question about Blodgett CTB BASE Electric Single Oven
Blower motor making loud noise, seems like its starting to bind
I have a Bosch white single wall oven HBL54AUC. It is very loud and I don't know why. It works...just too loud. Any suggestions? Linda :
Good morning Linda, the noise you're hearing is probably the cooling fan with a bad bearing. That would be the only moving part that would make noise. It's a pain in the neck to get to but fairly easy to swap out. Definitely easier with two people. Or it could be a bad bearing on the convection fan motor. Set it to temp and then open the door once it starts to heat, That will cut power to convection fan and noise will stop.Hope that helps.
Feb 08, 2018 | Bosch Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Turbochef loud noise
You have blower motor bearing problem. If it only make noise during cooking Thanks Please rate me
Nov 14, 2011 | TurboChef TORNADO Electric Oven
My whirlpool oven (model rbs305) makes a loud noise whenever it is on. I can't figure out if it's the fan, or just extremely loud.
I would suspect that the blower is noisy its what i would expect to potentially make noise ...if fits in the back of the control panel and it comes on to cool the control board each time the oven is on.
In case it turns out to be the blower thats noisy the part number for it is W10176670
GENE
Sep 10, 2011 | Whirlpool RBS305PD Electric Single Oven
I have tornado electric oven.My blower motor is keep making noise(seems that it is getting more power to run).I checked motor resistance and its okay.Any suggetions
Until the oven receives cook commands, it will continue to cycle until you give it a command.
Turn it from idle mode to off mode. Should be in your user manual page 11...
http://www.turbochef.com/filemanager/23/Tornado_Owners_Manual_NA_EU_NGC1006_G.pdf
FixYa Support
Aug 23, 2011 | TurboChef TORNADO Electric Oven
Seems like the blower motor is making a lot of grinding noise and the fan is not spinning quickly. also the fan continues to spin when the door is open.
the blower wheel has come loose from it's base, this happens a lot with ovens where aluminium foil is used, as the Moffat oven was designed to be the ultimate pastry oven, free flow air system was designed into it, I would start with the blower wheel as it is usually the cheaper of the 2 to buy.
May 24, 2011 | Moffat Ovens
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
FAN ON OVEN HAS STARTED TO MAKE VERY LOUD RATTLE
i wpould suggest tto look at the fan blades and see ig there's any thing on them, if there isn't then your blower bearing is going oiut on youe motor.
Dec 21, 2008 | Zanussi Ovens
Blodgett CTB BASE Electric Single Oven Logo
62 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
