Question about Microwave Ovens
Microwave works but does not get hot. GE - Microwave Ovens
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 18, 2011
Have A GE jvm230bv microwave. It work fine but even when not in use the inside of the microwave is very hot to the touch. Is this a problem?
I would not think it would be hot when not used . might be a short waiting to burn your home down . get an electrician to check it .
Aug 03, 2015 | GE Microwave Ovens
My microwave oven appears to be working, but the food does not get hot!
In many cases, the problem is a bad connection or a bad relay on the control board. If you send the microwave in to GE they should be able to fix it for $30 to $40 dollars
Dec 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave works but doesnt get hot
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
l
Apr 11, 2010 | General Electric Microwave Oven
Heat won't work on ge spacesaver microwave oven --what to do from
heatman101
ioi
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spilled some water on top ge micro wave while cleaning cabinets
YOUR BLOWER FAN MAY HAVE QUIT AND WITHOUT THE AIR CIRCULATION IT OVERHEATIND THE INTERNALS OF IT AND UNFORTUNATELY THIS UNIT WILL COST YOU MORE TO FIX THAN GETTING A NEW ONE. RED HOT IS VERY BAD ON A MICROWAVE
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE zmc1095 microwave beeps and indicates "HOT" in the display
If it stops heating it needs a new magnetron. our oven is less than 2 years old and has gone thru 2 magnetrons so far. Hoping to get some help from GE.
Jan 28, 2009 | GE JVM2050 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
