Hi. I have a very old Selectric II machine and I have totally forgotten how to install the correcting ribbom on it. Can you help me?
    Scholar:
    New Friend:
  • 135 Answers
I think youll find the instructions here:
www.selectric.org/selectric/manualii/index.html
good luck.
kc
Posted on Mar 18, 2011
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
I would love to have the PDF of the Correcting Selectric II instruction manual. Thanks so much for offering this as a free service. You are great!
Ebay is your best bet for this one! I've found manuals for many older devices there, including a 100 year old cash register. You may have to add it as al "alert" it there's not one listed now, but I guarantee there will be eventually, and if you utilize the alert system Ebay offers, you'll be notified when one is listed for sale. Good luck!
Nov 17, 2013 | IBM Correcting Selectric II
Problem with Selectric II typewriter engaging when turned on
Your on/off switch may be bad but it sounds like your motor needs to be flushed, lubed, and possibly have a bushing installed.
May 16, 2013 | IBM Correcting Selectric II
IBM Selectric II jammed
The lubricants dryp over the years. Try spraying everything with WD40 you can't hurt it.
DickyO
Feb 23, 2013 | IBM Correcting Selectric II
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
k24674
