Question about HP Pavilion (F2111-60950) CPU Heatsink & Fan
CPU fan not working computer shuts down. Replaced fan and it still does this? Hp Pavilion 9597c
  • 63 Answers
Its possible that the Motherboard connector for the fan is not putting out power. there are CPU fans that use a standard 4pin Molex connector, that is what I would suggest you use.
Posted on Mar 18, 2011
My hp pavilion g7 is overheating and shutting down
first check your ventilation port on the side or back of your laptop. These can become covered in dust and make your laptop very hot. After you've done that, if it's still overheating, try and find a free cpu fan diagnostic tool and make sure the fan is even running or if it's running at the proper speeds. If it's not running, check your drivers. Go to the hp website, then support and downlads and lookup your model laptop. It's on the bottom of your laptop. Download the cpu fan driver if available and reinstall it. If it's still not working after all of that, your fan is shot and will need to be replaced.
Aug 05, 2013 | HP Pavilion dv7-1285dx Notebook
My hp pavilion dv9720us will run for about ten mins and then shut off
you can try to hover around the fan outlet the dust gathers and stops the cpu cooling down and then the cpu wiil shut down to protect the laptop from overheating if it runs longer but shuts down you will need to get in to the laptop and do the same around the heatsink fan and cpu
Jan 08, 2013 | HP Pavilion dv9000z Notebook
The fan in hp pavilion dv7-1245dx does not work
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 07, 2012 | HP Pavilion dv7-1245dx Notebook
PThe computer turn off after 10 minutes of use, and then indicated that a problem is with the hard disk. Indicated, insert the instalation cd, but i don't have it.
ok if the computer works for about 10 minutes then shuts down then i would say its not the hard drive but the cpu fan. when your cpu heats up it shuts down when it reaches a certain temperature to protect itself. open your case and check that the cpu fan is working if not check it is plugged in correctly by unplugging it then plugging it back in, somtimes the connections can become oxidised and loose contact. if your cpu fan is working then let me know and we will try something else. let me know how you go.
Jan 20, 2011 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Got a screen message that fan is not working. Now when I turn on the computer it just beeps at me. What do I need to do to solve this problem?
Open cover and switch it on, check if fans turn (assume CPU fan), if not switch it off and remove from mains, replace faulty fan or clean the fan with a small brush and vacuum cleaner might be clogged with dust. If this fails check bios settings for CPU temperature and adjust accordingly, do not exceed recommended CPU temperature, or CPU will overheat and eventually be destroyed.
Computer shuts down and beeps due to over heating and bios shuts down machine as a precaution.
Jan 15, 2011 | HP Pavilion m7650n (RF254AA) PC Desktop
Hp Pavilion dv9000 powers on, then shutdowns, and keeps repeating.
Try it without the battery inserted with the AC adapter.
Jan 04, 2010 | HP Computers & Internet
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
Hp pavilion zd8000 random shut downs..?
it might be broken... Call a proffession and get it fixed
Dec 16, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion a1010n won't start
Make sure there is no dust covering the computer fan. If necessary use the recovery CD or a new Windows XP CD.
Jul 29, 2008 | HP Pavilion a1010n (PS563AA) PC Desktop
Pavilion DV 9005 issue
Please Reviewe all connections care fully. Its Very sensitive issue. If you do not find any open connection. Once again fit the fan with all connections. No display is nothing with Display do not touch that area. See only cooling Fan.
Best Regards
Rafique
Mar 15, 2008 | HP Pavilion dv9005us Notebook
HP Pavilion (F2111-60950) CPU Heatsink & Fan Logo
301 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
