Question about Dakota Alert M538-ht CB Radio
Can you tell me the antenna stud size for a Dakota Alert M-538 HT MURS radio?
  • Ted Collins
    Ted Collins Feb 23, 2014
    The comment that it is an SMA connector is incorrect. The Dakota Alert M538-HT MURS Hand Held uses a metric stud and is non-standard. Check eBay for the adapter. There is someone who makes custom antenna adapters for these radios.
  • Bob Deaner
    Bob Deaner Oct 09, 2014
    Do you have a link? I've checked and couldn't find anything. Thanks.
  • 3,018 Answers
It's called a reverse SMA. You can get a reverse SMA (f) to BNC (m) adapter for $5 and put any MURS antenna on it you wish. Here is a link to where I get mine at. Reliable people there. LAN SMA-38-TGN ( SMA female - BNC male ) http://www.associatedradio.com/ about midway down the page under RF adapters.
Posted on Mar 18, 2011
Testimonial: "Fast answer and thorough,nailed the solution, and even did a couple of follow-up checks with more information. Impressive, I do Tech Support and know!"
  • 2 more comments
  • Iron
    Iron Mar 18, 2011
    Correction, you need the REVERSE sma (f) to bnc (f) . I get them there all the time. The pic seems to not be displayed at this time but if you call them I know they have them.
  • kevin_smi403 Mar 18, 2011
    OK, Thanks! Big help.
  • Iron
    Iron Mar 18, 2011
    I did find a picture of it. Go to the same link http://www.associatedradio.com/ and click on the WOUXUN RADIO (top left). There is a list of accessories there. Third one from the bottom is your adapter. The reason they do this is to protect your radio. With the standard SMA antenna if it broke your radio too broke. With the reverse if you snap the antenna you dig the piece out and buy a new antenna and your radio is sparred.
  • Iron
    Iron Mar 18, 2011
    Glad it helped you. Any more questions feel free to ask.
What radios are compatable with motorola rdm2070d
The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
Jul 20, 2014 | Motorola Radio Communications
Can a RDM2080D pair with a BPR40?
If your BPR40s are VHF (model number beginning AAH84K), the answer is yes. The BPR40s can be reprogrammed to match your new RDM2080D VHF MURS radios. This can be done by an authorized Motorola dealer with a current software subscription. (If you cannot find a dealer, look us up online, we will be happy to assist.)
You might want to consider keeping your BPR40s around. The BPR40 has a more economical battery replacement cost (under $35), and is repairable/recondition. (currently $69 flat rate)
Your BPR40s are also capable of more wattage than the RDM2080, 5 watts vs. 2 watts. However, it should be noted the BPR40s will need to be programmed to the lower wattage when going to the MURS frequencies.
Best regards.
Jan 22, 2014 | Motorola rdm2080bfaas rdm2080d 8ch murs...
1997 dodge dakota truck radio stereo audio wiring diagram
1997 Dodge Dakota Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
Also, this coudl be interesting: Dodge Dakota Trucks at 1996
Hope helps (remember to rate and comment this answer).
Apr 29, 2011 | Car Audio & Video
29 lx le new 200 wilson antenna new coax and radio .we set the swr with a good meter at 1.2 and the radio says 3 or so and the message on the radio says cb antenna warning.and we doudle check the swr with...
what kind of meter? I would go by what is in the radio unless you are using an analyzer.
You may also be getting common mode current. take 6 to 8 inches of coax and make a tight coil about the same size as a spray paint can. Hold it together with electrical tape.
Use the meter in the LX LE to set the SWR then check with the other meter.
Nov 16, 2010 | Cobra 29 NW CB Radio
Radio wiring diagram for 94 dodge dakota
1994 Dodge Dakota Car Stereo Wiring Diagram
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Violet/White
Right Front Speaker Negative Wire (-): Brown/Blue
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Red
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Red
This should help and thank you for using Fixya.
Mar 06, 2010 | 1994 Dodge Dakota Club Cab
I dont know which wires are which in the dash of a 1987 dodge dakota
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black/Yellow
Left Rear Speaker Negative Wire (-): Gray
Right Rear Speaker Negative Wire (-): Blue/Orange
May 04, 2009 | Car Audio & Video
I LOST THE ANTENNA FOR JEEP WRSS 3A BOOMBOX
I have the same boombox and lost my antenna. I ended up going to my local Walmart and bought a generic rubber moulded car antenna. The studs that came with the antenna had threads and too large of a diameter so I carefully filed/ground the threads down until I acheived the correct diameter necessary for the antenna stud to slip into the antenna receptacle. It works great and looks as if it came with the radio to begin with. I hope this helped!
Apr 22, 2009 | Jeep JX-CHR Boombox
2000 flhtcui broken tour pak radio antenna stud replacement
the stud is held in place by the cable jack. unscrew the jack from the back of the assy inside the pack under the liner. The stud should just slip out. You do not have to remove the entire light assy to do this. Just the part the cable screws onto.
Sep 20, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Cant transmit out
Not really enough info to help you, but you MUST check the SWR of your antenna system. I've seen many cases where the antenna studs were incorrectly installed, shorting the antennas to ground. Also, make sure the Dynamike control on the CB radio is turned fully clockwise.
Aug 23, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Dakota Alert M538-ht CB Radio Logo
731 people viewed this question
Top Dakota Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Dakota Radio Communication Expert? Answer questions, earn points and help others
