Question about Hoover AAA140 Front Load Washer
Think some fluff or a sock is caught up somewhere as the water does not drain away and in order to get rid of the water I need to open the front flap and unscew the 'thing' behind it - how can I get in bahind that area to clear the blockage? Look forward to hearing from you with hopefully a simple-for-me solution ........ please many thanks Leah
    Brigadier General:
  • 6,277 Answers
(The filter should be just inside the tube behind the 'thing' you unscrew! You should not need to get behind that area as the drain motor is immediately behind the filter and can be checked for debris- see my guidance notes!)
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
Tip
To maintain your front loader washing machine in good working order and to avoid...
To maintain your front loader washing machine in good working order and to avoid having a service call there are a few simple maintenance tasks to carry out.
1. Every time you carry out a wash before you switch on the unit you should check the door seal for any foreign particles like coins or hair clips and remove them. If they stay there they can then get past the seal and clog up the fluff filter and drain pump which stops the unit from draining.
2. It is also a good idea to wipe the door seal occasionally
3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap.
Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand.
Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight.
This should be done regularly every 2-3 months to avoid the unit from not draining.
4. Running a cottons 95c wash every 2-3 months kills off any bacteria build up, and cleans out any excess detergent build up. It also stops the unit from smelling.
You can also use a special washing machine cleaner or just white vinegar as a cleaning agent in the detergent tray to help.
5. After every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect environment for bacteria to develop and the door seal to go mouldy and also causing the unit to smell.
6. Lastly take care when removing clothes as zips can catch on the rubber door seal and tear it. This will then leak water at the bottom of the door.
Hope this helps.
on Mar 26, 2010 | Kitchen Appliances - Others
Tip
How to maintain your Front loader washing machine.
3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand.
Hope this helps.
on Mar 21, 2010 | Washing Machines
Frigidaire model fex831fs4 will not drain or spin
My problem was a little different but I want to post this for others that might experience the same.
My Frigidaire Washer/Dryer Stack Combo Model FEX831FS4 was not draining and had a humming/buzzing noise when it got to drain/rinse cycle. This is usually and probably caused by a small sock or thin or small underwear that got sucked out the top and into the drain hose. I have no idea why they did not design this with a rubber flap like most washers to protect from items going up and out but here's how you fix it.
IF your unit is having this issue STOP and don't try runnin drain/rinse cylces anymore or you may damage the water pump and have to buy a new one. I think I damaged mine from trying to drain the water so many times with a sock clogged in there... but so far it is working anyway, just with a buzzing noise.
HERES THE FIX
You need to TAKE OFF the FRONT COVER and REMOVE the ITEMS FROM the HOSE leading to the WATER PUMP. The water pump is on the bottom front left and theres only TWO SCREWS to get off the FRONT COVER of the washer/dryer. They are on the bottom by the feet. Have someone tilt the unit backwards and unscrew them with a phillips head and then pull the front cover down and off. There is a rubber snap pin in the top center of the cover but it will come loose as you pull down.
In order to get at the water pump you do NOT need to pull the washer/dryer out, you can get at everything from the front. However it might be a wise decision to unplug the power since water will be draining everywhere.
First siphon out all the water in the tub, whatever you don't siphon will immediately coming rushing out once you remove the hose from the water pump.
I would UNPLUG the electrical connector on that water pump and tie it up out of the way because even if you siphoned the water there will still be water in the hoses and probably under the washer tub some.
Disconnect the hose that comes from the tub to the water pump. That's where I found a small children's sock clogging the pump. Dry off the water pump plug connector pins if they got wet (where you removed the plug from) and reconnect the electric connector.
We tried many times to run the drain cycle before taking the washer/dryer apart so your water pump might be shot as I think mine is. Now mine always makes a buzzing noise as if it's wore out from being worked with a sock blocking it's inner part. You might need to replace your water pump.
May 08, 2012 | Frigidaire FEX831F Top Load Stacked Washer...
How do you clean the filter?
There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight. This should be done regularly every 2-3 months to avoid the unit from not draining.
Aug 20, 2010 | Whirlpool Washing Machines
There seems to be water being retained in the machine
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there should be whats cauld a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.Alternatively water might be sigphoning back thru the drain hose into the machine.I hope this was helpfull.
Jun 01, 2010 | Samsung WF337AA Front Load Washer
Clothes come out still very wet...all water isn't draining I think. I tried to run it with no clothes (only detergent), and the service light came on at the very end of the wash cycle. My opinion...
john let's find the sock .. not knowing the brand .? take the front off the pump may have a turn cover /turn it and remove sock . other brands you will have to remove hose to get sock .. give it a good try . i think your on the reight track..mm hope this helped.
Dec 06, 2009 | Washing Machines
F 2 error message
Try the following:
1) Turn off breaker to unit, for safety.
2) removed the front panel, as described above.
3) removed the screw holding the drain pump filter assembly to the main unit.
4) gently pulled the drain pump filter assembly out of the channels holding it to the washer chasis.
5) gently pulled it out far enough to reach over a car washing bucket I had put into the open riser drawer.
6) gently unscrew the filter drain knob enough to release water into the bucket. If your using a smaller drain catch (cooking pan, oil pan, etc) you'll likely need to close the drain knob and empty your water.
7) once all the water was out (~3 gallons I think), I pulled out the filter to find my prize..... Five of my 2 year old's missing socks, including some since he was a newborn. Yeah... yuck!
8) cleaned out the filter and filter assembly... and threw away the socks and other goop.
9) Put it all back together: put the filter back in, returned it to its chasis housing, and put the screw back in the filter assembly. Then, put the front panel back on and flipped the breaker back on.
Good Luck!!
Thanks
Jun 30, 2009 | Kenmore Elite 45986 Front Load Washer
Smelly drum
is the water draining ok and is washer spining ok?,if this problem is recent a small kids sock or something could be sitting somewhere beside element or in drain pipework,first you could try a 90degree wash with nothing in drum,this will get rid of any undissolved detergent/powder which can stink sometimes if low temp washes are used alot
May 06, 2009 | Indesit W 123 Front Load Washer
Washer spins slowly & won't drain
Look at the bottom of the front panel. There on either side is a philips head screw. removing these will release the front panel. the upper part may have spring clips to the top. clearly it is nearly impossible for a sock to get stuck in the pump as the water drains out through all them tiny holes in the drum. look for a broken belt. there should be two of them. the motor is in the left front portion of the washer and is spring loaded to push out from the center.
Dec 24, 2006 | Maytag PAV2300 Top Load Washer
Hoover AAA140 Front Load Washer Logo
70 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
