Question about Toshiba Satellite L455S5000 Notebook
Power led on, but dont respond well, and no display.
  • fuser1234
    fuser1234 Mar 18, 2011
    Do you hear any sounds coming from the laptop like a fan or hard drive noise?
    Scholar:
  • 60 Answers
Its possible your screen's backlight is out, normally a easy way to tell this is by holding it up to the light and looking at it from an angle while moving around the mouse.
Another thing to try is to tilt the notebook's lid back and forth slowly and see if you see any blinking, if its blinks, then your video cable has been damaged and you will need to replace it or hire someone to replace it.
if you can't see anything on the screen when you test for the backlight, and you don't see any blinking then its possible your cable was just unplugged. and you will need to open up the notebook and plug it back in or hire someone to do so.
Hope This Helps.
Posted on Mar 18, 2011
    Problem Solver:
  • 18 Answers
Most likely a problem with the motherboard(main component of computer). If it is a problem with the motherboard, it will need to be replaced.
Try the following before getting the motherboard replaced or getting a new notebook(better idea).
1) Unplug the ac adapter wire and take out the battery.
2) Remove the Memory(RAM) sticks.
3) Hold the Power button for 30 Seconds.
4) Put back the memory and plug in the AC adapter wire only.
Model S400CA-CA006H, Power ON, only back lit blank display. Battery icon is green while the BULB icon LED is orange in colour.
  • rjsymmes has the most accurate solution. Start with a battery replacement. Next course of action is to use a Bootable Media Source (Windows Disk or Recovery Disk) to see if the laptop responds and can have the Start Up repaired. If a Boot Media fails, then examine RAM, Hard Drive removal, then boot. Last resort Motherboard.
Jun 22, 2014 | ASUS Computers & Internet
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
Samsung SMT-H3270 DVR not responding at all
The DVR unit still have power and display functions on the DVR small LED screen indicator on the DVR unit correct?And the DVR unit have not been in used for awhile and alway been plug in the power outlet for power like 24/7 hrs for power correct?Yes to all these questions,possible the DVR unit have software lockup or power glities some where before,possible the DVR unit have lockup and looping the software firmware of DVR unit not responding correctly for to the DVR unit to work or responding to any screen display functions.Tries unplugging the DVR unit for like about an hour and plugging power it back in for the DVR unit for the software to reboot itself.90 to 95% the unit will work again as u first got the DVR unit.
Oct 28, 2012 | Computers & Internet
I have LG LCD TV Model No: 22LF12R. The problem is the TV fell face down when it was still powered ON. Now when you switch it on the power LED comes on but there is nothing on the screen. When you press...
In my experience, there will be damage to the main pcboard, usually under the transformer.
If you are lucky you can find all of the broken track and remake the track.
Good luck.
Feb 25, 2011 | LG Televison & Video
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
My monitor will no turn on what do i do
1. Verify power cord is plugged-in and supplying power to monitor.
2. Verify Cord in between CPU & monitor is responding. (if it doesn't it will display Dell logo on dell monitors).
3. Press Power button and see LED turns green.
Sep 12, 2009 | Dell Computers & Internet
Got power but no display
Please try the following DIY to confirm the part
1.remove the battery and check on adapter mode.
2.If not powering on then check with refixing the battery.
3.if no use then check any LED is glowing,check with taping the num lock and if the LED responds then this is the memory issue otherwise a MB issue.
Jun 12, 2009 | Acer Aspire One AOA150-1570 Notebook PC
ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
Jan 18, 2009 | U-Line Refrigerator Ice Maker
Inspiron E 1405 laptop won't turn off and displays black screen
If it turns black again, try to check first if it's just the LED's that are defective. If you push the monitor 40 degrees down, and you can see very faint display from that angle, then it's probably that the LED's are the culprit, and you can have it replaced for a less price.
Jan 12, 2009 | Dell Inspiron E1405 Notebook
Bosch dishwasher not working
board needs replacement.
Sep 04, 2007 | Dishwashers
Toshiba Satellite L455S5000 Notebook Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
