Question about Toshiba 27A51 27" TV
TV took a long time to come on (about 50 minutes). TV kept clicking like it was trying to come on. When I attempted to turn it off, I could not turn it off.
  • 3 more comments
  • farmington44 Mar 19, 2011
    It is 27A51
    Is the power supply in the TV itself?
  • farmington44 Mar 21, 2011
    Thank you for all your help. This is kind of a mystery to me ... I have had no further trouble with the TV since the original occurrence, in fact it might even be going on a bit faster than before. I guess I wonder if this is "normal", is it just a matter of time before it dies? Is it worth it to get a 10-11 year old TV repaired?
  • farmington44 Mar 31, 2011
    The TV is now at repair shop. It is not the capacitor - power supply is now the possible problem, it's $45 to be looked at.
  • farmington44 Apr 02, 2011
    Hi, the power supply was rebuilt. Hope this solves it. The picture is no long wavy & it comes on real quick, so all it well. It cost about $150 for diagnosis & repair.
  • 10,594 Answers
Please confirm tv model number as question shows it is Toshiba 27A51
Model number is very important info of tv to look into related schematics for possible cause of problem and to suggest a solution.
Symptom shows it is either bad capacitor, devalued resistor in power supply section or cold/ dry solder connections in deflection section of tv.
Thanks.
Posted on Mar 18, 2011
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Mar 19, 2011
    Please check capacitor C507(470UF/ 200V) in power supply section, it is big capacitor, replace it if found leaky or its top is puffed.
    Thanks.
    Yes, you will see that capacitor nearby AC cord plugged in main circuit board of tv.
    Shahid Electronics Mar 21, 2011
    Now I'm thinking about cold/ dry solder joints/ connections on main circuit board of tv. Its good to know that tv is working without problem and if picture is still good then should be repaired under $50 ~ 60
    Hope this will help.
    Thanks, have nice day.
    Shahid Electronics Mar 31, 2011
    Wow, so it worked few days without any problem then shut off again?
    Well tv is in front of repair shop guys so let them fix it. Good luck.
    Shahid Electronics Apr 02, 2011
    Good to know that tv is working again.
    Have nice time.
Tv went black no sound either. TV only five years old,is there anything i can do? Thanks James
Cannot offer solution but my mine has also gone bad.  At first a black shadow appeared on the left side of the screen.  Took it to the authorized service center.  they kept it a few days, said nothing could be done.  Used it anyway for the next 5 years when suddenly it went black (or sometimes blue) after working perfectly for the first 5 minutes. A sharp rap next to the right speaker fixed it a few times, but no more.  Good luck.
Bill
kepner13@olympus.net
Jul 18, 2011 | Maxent MX5020 50 in. Plasma Television
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
My TV can't turn on and getting clicking sounds...help please!!!
I have a Samsung Plasma PN50A450 and one night the TV turned off and the result of trying to turn it back on was simply the set trying to turn on, making a click sound and nothing happened. I pulled the back off, and attempted the capacitor fix that is well documented on the Samsung LCD TVs. I did have a swelled capacitor that I replaced and also replaced the other capacitors that were the same Microfarad rating, temp and voltage which were replaced in a popular UTube video. That did not solve my problem, so I went onto Ebay and bought an entirely new power board for 69.00 plus 14.99 shipping. Replacing the board took about 3 minutes. TV is now working fine and will go back up on the wall in a day or 2. Note, the power board in my TV was a BN44-00205A. That board is no longer in stock anywhere ( I believe because it has been determined to be a bad board) I replaced it with BN44-00207A. Which I suspect is the board that is being used for replacements of the bad BN44-00205A. It fixed My TV. Hope this helps you. BTW, Both power boards are listed for replacing a board in the PN50A450, but the BN44-00207A Specifically states its for a PN50A450P1D. I took a gamble that the BN4400207A would work. It did.
Mar 01, 2010 | Samsung PN50A450 50 in. Plasma HDTV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
My phone keeps freezing...
my phone froze and i attenpted to turn it off several times, after trying and not getting a response i took out the battery pack and placed it back in and turned the phone back on. after turning the phone back on it kept freezing a
Nov 24, 2007 | Nokia N81 Smartphone
Toshiba 27A51 27" TV Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
