Question about Haier Washing Machines
THE DRUM WILL NOT TURN,when machin is switched on THE LCD DISPLY SAYS ERROR SOMETIMES
    Brigadier General:
  • 6,277 Answers
This sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
Hope this is your problem solved.
Good luck,
John C
Posted on Mar 18, 2011
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
I am getting the message print unable 28. I just replaced the drum unit. What is wrong?
The error means there is an issue with the black/yellow drum drive motor. Try taking out the drum unit and first see if anything broken within the drum unit. If drum unit looks OK you will probably have to replace the motor.
Mar 08, 2014 | Brother MFC-9840CDW Laser Printer
Alarm F10 is displyed , my washer/dryer doesnt
Hotpoint error code F10 is
"No cold fill. Check that the taps are on or if the drain hoses are kinked".
Has someone turned off the water supply or the isolator valve on the plumbing?
If not, you may have a faulty inlet valve on the machine.
Please drop a comment back on this thread if you require further help or guidance
Jul 21, 2011 | Hotpoint Washing Machines
We are getting the oL message even when we wash a light load or even run the machine empty. The machine seems to be spinning, but cuts off with the "oL" message sometime between the rinse and...
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Feb 18, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Drum stopped turning no air blows, no error code
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Oct 20, 2009 | Samsung DV448AEE Electric Dryer
Alesissr 18 drum machine lcd does not display
Check if there is a contrast setting... Unfortunately, sometimes the setting can;t be viewed when contrast is too low. Read your manual and find how to get into that mode if it exists and turn it up.
Jul 16, 2009 | Alesis Sr 16 Stereo Drum Machine
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
ERROR CODE
Hi,Pls to shut - down the unit and try to power on ,may be its malfunction the control LCD.
THANX
Edgz
Mar 30, 2008 | Heating & Cooling
Error message
???????????? you did not specify model or make??
the only one I could find is a minolta w/c610 error
Lens motor drive
when you turn on the machine is the lens suppose to move to find home in vert and hor mode? Then, check motor to see if it moves lens
Jan 16, 2008 | Office Equipment & Supplies
Washing Machines Logo
78 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
