Question about Refrigerators
KBLS22KTSS00 Kitchen Aid Fridge Every so often, the fridge makes a knocking type noise, almost like a motor vehicle 'running on' after the key has been turned off. There are no cooling problems or any other problems that I can tell Any clues?
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
Posted on Mar 18, 2011
My kitchen aid refrigerator won't stop buzzing
If everything is cooling right, take the front grille off at the bottom of the fridge and move the plastic drip tray. It might be touching the motor or pipe, causing the noise.
Jan 28, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Just purchased this fridge and the motor appears to be running quite often and loud. Think it is noisier than it should be for a new fridge - is this normal or is there a problem. Had a Kitchen aid...
Normally all what is heard is HUM which needs one to listen. Hiowever is you experience a high noise then being a priviledge customer you need to get a consensus to your viewpoint as the fridge is covered with warranty.
Please check for SYMPATHETIC vibrations on the rear panel due to loose fitting which can happen with transportation.
Your observation is most important.
Thank you for using fixya.
Sep 02, 2011 | Fisher and Paykel Active Smart® E522BR...
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Refrigerator knocking noise
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Nov 15, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
