I have tried replacing my honeywell twice in the past year. My problem is that I have to push and try and move my thermostat around for the ac to kick on. Once I can get the ac on, it turns off again and I have to go back to the thermostat and move it around on the wall unitl the unit comes on. I have to open a window to make sure the outside until kicks on, as this is the only way I can cool the house. Is this a wire problem in the wall?
    Genius:
  • 1,033 Answers
Hello, sounds like the problem Is a wiring issue, there might be a loose wire in the wall causing this problem with your thermostat, however usually the wires don't get loose in the wall unless they were spliced. Also, make sure the connections on the thermostat sub base are tight to each terminal and that the thermostat is mounted securely to the wall.
Posted on Mar 18, 2011
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
Tip
Programmable Honeywell
A Programmable Honeywell Thermostat is a great investment for you to make for your heating and cooling system. A Honeywell Thermostat will provide you with the best in comfort and dependability for many years.
Many people when they think of Honeywell Thermostats think of the old round T87 thermostat that has been one of the most common thermostats for years and years.
Today they have those thermostats in designer colors and they are still made and used in many situations. But the manual thermostat is quickly becoming a thing of the past. With the rising costs of fuel the Programmable Honeywell Thermostat is becoming more and more popular. Programmable Thermostat Honeywell is even one of the most popular searches when it comes to thermostats.
The VisionPro thermostat line has quickly become one of the leading digital programmable thermostats on the market to today. The ease of programming this thermostat and the touch screen interface has made it a very popular choice for many people. There is a variation of this thermostat for virtually any possibility that you can think of. The FocusPro line also is a very good choice at a bit less cost. There is a basic Pro line and also even a digital thermostat in the traditional round configuration. Both digital programmable and basic digital thermostats are available for line voltage control of electric heating.
Along with the thermostats you now are able to add remote outdoor sensors as well as install you thermostat in a remote place and run a sensor to the space you are controlling. For many years these capabilities were standard for commercial thermostats, but now they are a very real possibility for home use also. With an outdoor sensor these thermostats now have the capability to turn off your heat pump and start you backup heat a certain preset out door temperature. In the past many systems have been installed with complicated electronic to do what a thermostat can do very easily.
The Programmable Honeywell Thermostat has come a long ways in the past few years. The changes have made this thermostat capable of doing many unbelievable things. If you are looking to replace your old thermostat, carefully compare the many thermostats on the market and then pick the one that will meet your needs the best. For many the Honeywell digital thermostat will be the best choice, giving them great flexibility and reliability in one thermostat.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
on Jan 15, 2010 | Heating & Cooling
Honeywell ac thermostat not working
The replacement batteries may be no good or may have been installed with the wrong polarity. Also, if your Honeywell thermostat latches into a wall mount, you may have reinstalled it incorrectly. I speak from experience
Jun 18, 2013 | Heating & Cooling
Thermostat will not let us program the cooling past 72 we have tried to move the temporary setting also useing the hold temp button and pushing the decrease key, it seem to be locked at 72
you need to get into the installer settings to lower the minimum setpoint. look up your model online and try that. Otherwise you may have an older style auto changeover type t sat in which case you should still look up the manual and reprogram from the installer configs. or try buying a new one
Sep 13, 2009 | Honeywell Programmable Thermostat Heater
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Feb 04, 2008 | Honeywell Programmable Thermostat Heater
Battery backup?
which model do you have ? the 8000/8001 or 8011 the set is different depending on your type of heating system. This model has a memory chip not a battery that saves your settings. So you could be looking at replacing the unit.
Jan 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
152 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
