Question about Sylvania G-Netbook
I lost my password my screen is locked how can I reset or bypass?
  • Curtis Misiaszek Sep 25, 2011
    how can i unlock the screen without loosing the text messeages that are on the phone? I have a samsung Galaxy prevail m820
    Filmmaker:
    Uploaded 5 video answers.
  • 34 Answers
This is about topic bypass Windows logon screen. Command Prompt or recovery utility is effective ways for reset or bypass lost Windows password.
First, run command prompt with administrator. And you can reset Windows lost password with this command. Net user <new user> <new password>
Second, take recovery utility to burn a password reset disk. And this reset disk is the key to remove or reset Windows password, applied for standard or admin account. When your computer is installed with Windows 8/7/Vista, forgotten user password would be removed. If it is Windows server 2012/2008 etc, password would be reset as "iSunshare@2012".
Posted on Nov 21, 2013
    Scholar:
  • 67 Answers
If you have lost windows password, the best thing for you is creating a password reset disk.Actually,when you add a password to your pc,the first thing you should do is creating a disk in case you lost the password.But how to make a password reset disk after you have lost the password ? Follow these
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Key
Then let's begin
Step 1.Login to a PC which can link to internet,Download and install the program in that PC
Step 2.Run the program and burn to CD/DVD OR USB flash drive
Step 3.Turn to your locked PC,insert the newly create CD or USB to your drive.Reboot the Computer and then follow the instructions,it is very easy to use.
Posted on Mar 29, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 20 Answers
Hack HP Computer Password ' Erase HP Desktop / Laptop Password Without Being a Hacker
  • In my received E-mail that people ask to recover lost PC password, a quarter of people are using HP computers. So I prepare this tutorial specially for these HP users.
Posted on May 23, 2011
  • 21 Answers
Emm, forgot Windows 7 password?
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live cd,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Reset Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Steps:
Step 1: Download and install Windows Password Reset Tool from http://www.windowspasswordreset.net in any available computer.
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck ~
Posted on Jul 04, 2011
    Novelist:
  • 147 Answers
This solutionwill work if you have forgotten your Windows password. It will not work if youhave forgotten your boot password or hard drive password etc.
Read on if you want to use a USB flash drive. Scroll down if you would ratherburn a CD/DVD.
USB Flash Drive Method
You need to download a Windows passwordcracker, put it on a flash drive, and boot it outside of the Windowsenvironment. This solution will show you how to do that.
1. Download the Ophcrack Windows password cracker from here. For Windows7, click on the ophcrack Vista LiveCD.Ophcrack is one of the best free Windows password recovery tools available.It's fast and easy even for a first time Windows password cracker. Save file toDesktop.
2. Download Xboot 1.0.0.0 Beta 6 here. Savefile to Desktop. Unzip file and extract to Desktop.
3. Plug a USB flash drive into your PC and format it with a FAT32 filesystem. This can be done by opening "My Computer" and right clickingon the USB flash drive and selecting Format. Select FAT32 and click OK. (Note:this will erase all data on your flash drive.)
4. Open Xboot.exe. Select the Ophcrack ISO file you downloaded and drag it ontothe Xboot screen.
5. Click on "Create USB" found in the bottom right hand corner of theXboot window.
6. Select your USB drive and click OK. Wait for your USB flash drive to becreated.
7. Restart computer and press F10 or appropriate function key for your computerto enter the temporary boot menu. It may be F12 or F9 etc. Look at the firstscreen that appears when you turn on the computer and you will see which key topress. You also could enter the BIOS and change the boot order if you wouldprefer that method.
8. Select USB Flash Drivefrom the boot menu.
9. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Modeoption when it appears.
10. Ophcrack will automatically begin cracking your passwords. The longer andmore complicated the password is the longer it will take to crack. 99% ofpasswords are crackable. Any password over 14 characters cannot be cracked.This program found my 8 character password which contains letters and numbersin less than 10 minutes.
11. Write down your password when it's cracked. Remove the USB drive andrestart computer.
Good luck and thanks for using FixYa.
Burn a CD/DVD Method
You need to download a Windows password cracker, burn it to a CD/DVD,and boot it outside of the Windows environment. This solution will show you howto do that.
1. Download the Ophcrack Windows password cracker from here. For Windows 7, click on the ophcrack Vista LiveCD. Ophcrack is one of the best free Windowspassword recovery tools available. It's fast and easy even for a first time Windowspassword cracker. Save file to Desktop.
2. Burn the Ophcrack LiveCD ISO file to a CD/DVD using the Windows 7Disk Image Burner or another burning program. For Windows 7 users, pleasefollow steps 2a and 2b. If you are using Vistaor XP you will need to use a CD/DVD burning program already installed ordownload and install a free program such as the one here.
2a. Right click on the ISO file and select "Open with" and thenselect Windows Disk Image Burner or another CD/DVD burning program.
2b. Put a CD-R or DVD-R into the DVD/CD drive and select Burn. Wait for theburning process to finish.
3. Restart computer and press F10 or appropriate function key for your computerto enter the temporary boot menu. It may be F12 or F9 etc. Look at the firstscreen that appears when you turn on the computer and you will see which key topress. You also could enter the BIOS and change the boot order if you wouldprefer that method. Many computersalready have the CD/DVD drive as the first boot drive so you may not have to dothis step.
4. Select CD/DVD from the boot menu.
5. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Modeoption when it appears.
6. Ophcrack will automatically begin cracking your passwords. The longer andmore complicated the password is the longer it will take to crack. 99% ofpasswords are crackable. Any password over 14 characters cannot be cracked.This program found my 8 character password which contains letters and numbersin less than 10 minutes.
7. Write down your password when it's cracked. Remove the CD/DVD and restartcomputer.
Posted on Mar 18, 2011
    Scholar:
  • 60 Answers
Step 1: Start/Restart Your Computer. Step 2: Press F8 Repeatedly during startup. Step 3: Select 'Safe Mode'. (Top of the list) Step 4: Log Into 'Administrator' User Account. Step 5: Goto Start>Control Panel. Step 6: Goto 'User Accounts' Step 7: Double click the Account who's password you would like to reset. Step 8: Click 'Remove Password' Step 9: Verify that you want to remove the password by clicking "Remove Password" button Step 10: Goto Start>Power, and restart your computer.
Hope This Helps.
Bought a Fugitsu T4020D with a broken screen at a yard sale. Fixed the screen but it is password locked at BIOS, and before Windows loads. How can I unlock the BIOS to get into this thing?
1. Bypass Windows 7 Logon Password with Command Prompt While computer couldn't boot normally or notebook is infected with Trojans or malware, you can get rid of them by starting computer in Windows Safe Mode. Furthermore, when lost or forgot Windows password, you can also bypass Windows 7 logon password easily in Safe Mode.
In Windows 7, there are 3 different types of safe modes to choose, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. And the following guide is about how to bypass Windows login password with Command Prompt in Safe Mode. With net user command in Windows safe mode, you can reset Windows password effectively. Details as follows:
Step 1: Start or restart your Windows 7 computer.
Step 2: Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and then press Enter.
Step 4: Wait for Windows 7 files loading until Windows login screen comes up.
Step 5: Log in Windows with an administrator account until you see login screen.
Step 6: A Command Prompt appears. Type net user in the Command Prompt and then hit Enter. All Windows user accounts will be listed for you.
Step 7: Type net user iSunshare 12345 and hit Enter.
Note: "iSunshare" is your locked Windows user account name. And "12345" means the new password you want to reset for the locked account. User account "iSunshare" will be reset with new password "12345".
Step 8: The new password has been successfully reset for user when the command is completed successfully.
Step 9: Login Windows 7 PC with the new password.
Whenever you need to access Windows in Safe Mode, an administrator account password is necessary. So it is highly recommended that write down Windows password and store it or creating a Windows password recovery disk before Windows password lost.
May 11, 2016 | Computers & Internet
Tip
How to Bypass Windows Password?
Regarding computer security, the first thing a PC user may think of is to create a strong Windows password to protect unauthorized users. Actually, it is indeed the one of the aspects we usually do to enhance computer security. However, sometimes you may only focus on "strong" so you create a very complex Windows password, neglecting that you are unable to keep the strong password in mind. In that situation, the security measure may bring you a disaster without any benefits. In reality, there are many users suffered this similar matters. Searching in Yahoo Answer, you can find lots of questions concerning how to <a href="http://www.resetwindowspassword.com/bypass-windows-password.html">bypass Windows password</a> without reinstallation if Windows password lost.<br /><br /><span style="font-weight: bold;">Bypass Windows Password Option 1:</span><br /><br />If you are a Windows XP user, you can simply restart or start your computer to enter the Windows log-on screen. Then press Ctrl+Alt+Del twice and the classic Windows log-on screen will appear. Type administrator in the user name text box and leave the password text box blank, and then hit Enter to log on your computer. This method is only applicable as you don't set a password for the default administrator account.<br /><br />The above easy solution is not effective is your OS is Windows Vista or Windows 7. Unlike Window XP, the administrator account in Windows Vista and 7 is disabled by default. In addition to this bypass Windows password method, some other Windows password recovery options yet are not suitable for lost Windows Vista/7 password. Fortunately, there are 2 common methods allowing you to bypass Windows password in all popular Windows OS.<br /><br /><span style="font-weight: bold;">Bypass Windows Password Option 2:</span><br /><br />Whether your OS is Windows 7, Vista or XP, you can use a USB flash drive to create a password reset disk to in case of Windows password lost in a few minutes. With this password reset disk at hand, you can easily change the lost password with the disk. Unluckily, many of PC users is not aware of the importance of creating a password reset disk until they find password lost and cannot log on computer. Of course, some may don't know how to create a Windows password reset disk. If so, you can follow the steps as below:<br /><br />Step 1: Insert a removable media such as a USB flash drive or floppy in computer.<br /><br />Step 2: Open User Accounts by clicking the Start button, Control Panel, User Accounts and Family Safety, User Accounts in order.<br /><br />Step 3: In the left pane, click Create a password reset disk, and then forgotten password wizard will come up. You can easily create the password reset disk follow the instructions.<br /><br /><span style="font-weight: bold;">Bypass Windows Password Option 3:</span><br /><br />Windows Password Reset is a professionally Windows password reset tool which allows you to bypass Windows password if you are locked out of computer. With this password reset tool, you can easily burn a password reset CD/DVD or USB flash drive in any accessible computer firstly, then you can remove your <a href="http://www.resetwindowspassword.com/">lost Windows password</a> with the burned password reset CD/DVD or USB flash drive. It is easy to use, no special computer skills. And the whole operation just cost you less than 5 minutes.<br /><br />Step 1: Download and install Windows Password Reset.<br /><br />Step 2: Burn a password reset CD/DVD or USB flash drive.<br /><br />Step 3: Remove lost Windows password with the burned CD/DVD or USB drive.
on Nov 12, 2010 | Computers & Internet
Tip
How to Bypass Windows Password With Ease?
Nowadays, it comes a common sense to add a BIOS or Windows password for laptop protected. Thus, a feasible advice is to create a Windows password disk in case that you forgot Windows password. But without Windows password reset disk, what should we do in order to bypass Windows password?
It's time to learn how to bypass Windows password with the following two tips and tricks.
Method 1: Bypass Windows password by Safe Mode with Command Prompt
According to Wiki, Safe Mode is a diagnostic mode of a computer Operating System (OS), a special way for Windows to load when a system-critical problem interfering with normal operation of Windows. If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to bypass Windows password in Safe Mode when you lost or forgot Windows password.
Take Windows 7 for example: there are 3 different types of safe mode: Safe Mode, Safe Mode with Networking, and Safe Mode with Command Prompt. Below is a guide on how to bypass Windows 7 password with Safe Mode with Command Prompt, which allows you to bypass Windows password with command line. Detailed steps are as follow:
Step 1. Boot or reboot your Windows 7 computer.
Step 2. Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3. Choose Safe Mode with Command Prompt in the coming screen, then Press Enter.
Step 4. Wait for Windows 7 files to load until Windows login screen comes up.
Step 5. Log in with an administrator account when you see logon screen.
Step 6. A Command Prompt appears.Type net user in the Command Prompt and then hit Enter. All Windows user account names will be listed for you.
Step 7. Type net user 'Alina 123' and hit Enter.
Step 8. The new password has been successfully reset when the command is completed successfully.
Step 9. Log on your PC with the new password.
Note: 'Alina' is your locked Windows user account name. And '123' means the new password you want to reset for the locked account.
Whenever you need to log on to Safe Mode, an administrator account password is necessary. So it is highly recommended you to write Windows password down and sotre it or creating a Windows password recovery disk before lost/forgot Windows password.
Method 2: Bypass Windows password with Windows Password Unlocker
However, if you haven't created a password reset disk and forgot all administrator account password, it's better for you to bypass Windows 7 password with Windows password reset software. These reset software allow you to bypass Windows passwordwith a USB flash drive or bootable CD/DVD. Windows Password Unlocker Professional is one of the best choice to reset or change Windows password in a while.
Go through with these steps and recover Windows password with ease!
Step 1. Download Windows Password Unlocker Professional and install it in any computer.
Step 2. Run the program and burn an ISO image file into a blank CD/DVD or USB flash drive.
Step 3. Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4. bypass Windows password successfully.
Of course, there are some other methods of bypassing Windows 7 password. Picking up a suitable and efficient one to bypass Windows password is a necessity.
on Oct 28, 2010 | Computers & Internet
Forgot home screem password for android ipad
How to bypass Android's lock screen pattern, PIN or password
trendblog.net > Guides
Oct 18, 2015 - How to bypass Android's lock screen pattern, PIN or password ..... Hi can anyone help me I have lost my android tablet device in my bedroom ...
How to unlock an Android phone/tablet - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to unlock an Android phone/tablet
Feb 4, 2013 - But what do you do when you forget your own access code? ... Choose a new screen lock option, such as a pattern or PIN, then enter a code. ... If you've locked your Android smartphone or tablet with a PIN or password, ...
Forgot iPad Screen Lock Password - How to Recover Data ...
www.wondershare.com > Resource > iPhone
Jan 01, 2016 | Tablets & eReaders
How to bypass screen phone lock code Optimus Zip LG Straight talk Android or hard reset
If the phone is locked because you used the wrong password, there is no bypass.
If it was, the security was useless. The only way is to reset the phone and setup from scratch. All your data will be lost, so I hope you have made a backup of all the important things. (in the cloud perhaps?)
Sep 24, 2014 | Cell Phones
I'm forgot my password to login
If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to bypass Windows 7 logon password in Safe Mode when lost or forgot Windows password.
For Windows 7, there are 3 different types of safe mode, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. The following guide is about how to bypass Windows login password with Safe Mode with Command Prompt. With command in safe mode, you can reset Windows password. Details are as follow:
Step 4: Wait for Windows 7 files to load until Windows login screen comes up.
Step 5: Log in with an administrator account until you see login screen.
Step 7: Type "net user iSunshare 12345" and hit Enter.
reset-windows-password-with-cmd.png Step 8: The new password has been successfully reset when the command is completed successfully.
Step 9: Log on your PC with the new password.
Aug 21, 2014 | Computers & Internet
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Aug 06, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Wanting to unlock screen password
2 ways factory reset and remember the password. There are 3 ways to reset it but only 2 are accessible. There is a way to bypass the password lock but only if the phone was put into USB debugging mode before lost password. If this is so let me know I will step by step that method.K
May 23, 2014 | LG Optimus E612 White Android OS Unlocked...
Sylvania G-Netbook Logo
543 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
