Question about Dryers
When I push start button it just buzzes. I replaced the fuse and the start button and it is still buzzing for a frididare dryer fer6600fs0
  • 4,323 Answers
Hi
If the buzzing sound is coming from the bottom of the unit then the motor is bad and should be replaced however, if you hear the sound from the control area then the timer/control is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 18, 2011
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
The buzzing is a good sign that the motor is bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Maytag MDE9700AYM Electric Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Open Questions:
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
