Question about 2-Way Car Alarm System w/ Remote Start
I paid to have this alrarm and starter prof. installed, i was charged 125 and the startwer does not work, they said i need some type of manual that tell you how to program it to the car, Its been sucha hassle please help. Thankx
Numero de telefono
Posted on Mar 31, 2011
The ignition button wont work
Hi, Ryan before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Ktm Duke 125 Will Not Start
HELP Starting problem KTM Duke 125
http://www.ktm.com/globalassets/product-manuals-pim-data/dok_bike_bed_13_3211963_en_om__sen__aepi__v1.pdf
http://www.partsfish.com/page/oem-parts-for-ktm
http://www.motogelnar.cz/manual/KTM/KTM125-200_1999-2003ServiceManual.pdf
Apr 10, 2017 | KTM 2013 125 DUKE
94 bronco wont start
Go under and jumper the solenoid wire to the positive batter cable at the starter and see if it cranks over, if it does the startwer sub solenoid may be defective, it is near the battery and the positive cable goes to it from the battery and then out to the stater.
Mar 24, 2014 | Ford Bronco Cars & Trucks
I have a 1987 R/V with a 7.5 / 460 engine. I believe the starter bendix is wearing out as the last few times it started, the startwer failed to disengage following the start until a few seconds after. I...
Lower rear of engine, I think on the passenger side. Follow the red battery cable to it.
It could be the starter gear (bendix), or might be the solenoid contacts are sticking closed. You have the fender mounted relay (solenoid), do you not? May need to replace or check both.
Aug 13, 2013 | Cars & Trucks
Dt 125 electric start stopped working
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
GENERATOR ELECTRIC STARTERS DYNAMOS
Yamaha DT 125 RE electric starter removal
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
OEM parts for Yamaha
YAMAHA DT125R Owner Manual
Jun 30, 2013 | 2003 Yamaha DT 125 R
Piaggio zip 125 electrical
Hi, Bilywalker before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
Troubleshooting
Scooter Troubleshooting Scooter won start All about Scooters
Piaggio Fly 150 4T Workshop Manual
https://www.oemmotorparts.com/oem2.asp?M=piaggio
PIAGGIO MP3 125 User Manual
May 28, 2017 | Piaggio Motorcycles
I have an completely dead car battery and i need to know which setting is required in order to use the 2/15/125amp starter charger?
Disclaimer - I accept no responsibility for anything I say here. I may be wrong, so use your judgement on taking my advice.
Advice - First try the web and/or the manufacturer for the manual for the charger - if that fails, what I'd do for myself is...
125 for starting the car (ONLY, not charging the battery) 15A for charging dead/low battery 2A for maintaining battery
If 125 doesn't start the car, I'd call AAA
Feb 11, 2011 | Schumacher & Fast Charge Starter Charger
Yamaha Riva 125 wont start
Hi, Cb350four before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
8. Faulty kickstand, clutch, neutral safety switch.
Yamaha Riva 125 problem starting
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Yamaha XC125 Service Manual
YAMAHA CYGNUS XC125 Owner Manual
Mar 20, 2010 | 2000 Yamaha TW 125
Starter is good. but still no noise when key turns over.
rhere is a small wire and a large wire at the starter. you can use a jummper wire and jump from one wire to the other if you have voltage at the big wire it should crank over if the startwer is good. if not you have other issues with the starting system.
May 23, 2009 | 1995 Honda Accord
How do I remove and install a starter? Do I need
simple process.. just two bolts, and two or three wires.. you should be able to do the job, with just a couple of wrenches.. good luck keith...
Mar 20, 2009 | 2002 Jeep Grand Cherokee
2006 Yamaha XT 125 X remove starter motor
Hi, Ajs8tr for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $9 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
YAMAHA XT125X FULL SERVICE REPAIR MANUAL 2005 2014 Download Manuals... $9
YAMAHA XTZ 125K Owner Manual
Yamaha XT 125 2006
Yamaha XT125R Wikipedia
Mar 13, 2009 | 2006 Yamaha XT 125 X
2-Way Car Alarm System w/ Remote Start Logo
142 people viewed this question
Top Performance Teknique Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Performance Teknique Vehicle Part and Accessory Expert? Answer questions, earn points and help others
