Question about Samsung LN-S4095D 40 in. LCD HDTV
I have a Samsung LN-S4095D. I have vertical flickering (static like) lines going down on the middle left part of my screen. This problem only occurs when I'm on a 1080p signal
5 Suggested Answers
  • 179 Answers
SOURCE: problem with 1080p via hdmi?
are you hooking up a 1080p source..if not then the set will not display the best picture in 1080p mode..
Posted on Dec 01, 2007
  • 79 Answers
SOURCE: Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
Posted on May 22, 2009
  • 1779 Answers
SOURCE: My LCD model LN-S4095D has no picture or sound
Somewhat, take a dvd player and plug it into av1, switch your source to that and see if it's normal.
Posted on Oct 03, 2009
eagle338
  • 4889 Answers
SOURCE: i have a samsung 40
The fault you have mentioned is caused by faulty capacitors usually those on the Power supply board and/or SSB main board. I would suggest that you take a good look at the board and look for capacitors with swollen or cracked tops. The problem is caused by the caps unable to sustain their charge discharge cycle for a long time due to lost or corrupt electrolyte.
Posted on Nov 20, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Left side of display has flickering vertical lines
Bad video driver chip for that location. Needs to be serviced.
Jan 14, 2014 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-S4095D HDTV Screen Glitching
look to see if same issue with a DVD etc connected to a rear input.
Jun 07, 2012 | Samsung LN-S4095D 40 in. LCD HDTV
I have a line running thru my tv
vertical(up/down) or horizontal(left/right)? color/white? when you tap on the top of your tv does the line go back to a full screen? could be a makers defect.
Aug 22, 2011 | Samsung LN-S2651D 26 in. LCD Television
I have a samsung lns4095d and it has short horizontal white/red lines going down the center of the screen. They jump around, and it's on every screen....setup, cable, hdmi, etc...what is my problem?
Hi, Make sure that you don't have any florescent tube lights near your TV. The light has some affect on TVs. Move the TV away form light.
Do you have anything connected to the tv other than cable. If problem persist call repairman and see what he has to say. Good luck.
Jul 20, 2011 | Samsung LN-S4095D 40 in. LCD HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH LINES GOING THRU SCREEN AND PICTURE FLICKERS
CHECK LVDS CABLE FIRST, TAKE IT OUT OF THE T-CON BOARD FIRST AND RESEAT IT, THEN TAKE IT OUT OF THE MAIN BOARD SECOND, COULD GET LUCKY AND FIX IT, OTHER WISE THE SCREEN IS PROBABLY BAD
Dec 30, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
May 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Picture appears to be cracked
It is cracked. Maybe not the first layer, but for sure the lcd is cracked. This is the reason why you found it on the garbage. The lcd panel is way more expansive like the tv itself. You can sell it on ebay for parts.
Dec 31, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Open Questions:
See all Samsung LN-S4095D 40 in. LCD HDTV Questions
Samsung LN-S4095D 40 in. LCD HDTV Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
