My sony flat screen works but when I turned it on the colors are blue and purple. Picture not clear but sound is ok. Colors are off.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Press "Input Select" on the remote control and select "TV Mode."
Press "Menu."
Press "Enter" to select "Picture."Use the arrow buttons to select
"Picture Setting."
Press "Enter."Use the arrow buttons to select "Color."
Press "Enter."
Use the left and right arrow buttons to adjust the color settings. When you are pleased with the color setting, press the "Exit" button on your remote to exit the menu screen.
Hoped this helped
Posted on Mar 18, 2011
Hello, Ive bought a new Sony Bravia KDL37EX402 television a while back and hooked it up to my computer via hdmi. When i turn on the television it blinks after 3 to 5 minutes from black, back to the...
Sounds like something must be loose. Try seeing how secure the hdmi port is on both ends first, unplugging them and then firmly plugging them back in. Then if the problem still persists, try unplugging the T.V. for a solid minute and then plugging it back in. If it still occurs, something might be loose on the inside, and you'll probably need some outside repair work done. If you purchased a warranty then you should be covered. You should also be covered if you didn't but the T.V. is less than a year old.
Jun 07, 2011 | Televison & Video
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
What colors go where sony cdxf5700 install to
The aftermarket wiring colors are universal so this is for your Sony
Battery ---yellow
12 volts accessories-----red
Blue/White---- amp. Turn on
Blue---antenna turn on
Orange—illumination
Speakers wires are white;white/blk----green; green/blk---purple; purple/blk---gray; gray/blk. Now for your car I need to know the model
Jan 01, 2010 | Car Audio & Video
My tv is turning everything purple like it is
Hello :
The problem is your color purity is off. The earths magnetic poles cause this to happen on all direct view televisions, when you move a television or turn it from its usual viewing spot. You may have noticed a thump sound when you first cut on the television after its been off for a while, this is the televisions degaussing circuit mixing the color phospers in the picture tube. One way to clear this is to turn off the set for at least 20 mins and turning it back on this usually clears the purity. Have you ever had a older computer monitor and it had a button on it that says degauss an press it and you see a rainbow of colors then the screen goes back to normal. Well your television also has one too but does it when you first cut on the television you can't see the rainbow effect because the screen is still dark at this point.
If this does not work have a technician come out and degauss the set for u manually, using a degaussing coil.
Hope this explains your problem,,
Please leave a comment for futher assistance.
Delhielectronics@live.com
Sep 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue picture
im having the same problem hvnt figured it out yet, but when you put the screen on warm instead of standard or cold it helped mine,went from blue to not as bad pink .
Apr 10, 2008 | Acer AL2671W 26 in. LCD Television
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Colors flashing no picture
Did you have another monitor to verify the problem whether it is related with the Video card or the monitor itself?
Jul 29, 2007 | Xerox XG-71D 17" Flat Panel LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
