Question about Mitsubishi WT-46805 46" Rear Projection Television
I have a mitsubishi projection tv model wt-46805. It started not responding to the remote control, and over a period of about a week, it got worse. You could only turn it off and on with the power button. Eventually, the volume went to max, and then the tv turned off. I can tell I have power to the tv, because when you press the reset button, the green light flashes. A friend of mine tells me that I will need a tuner unit. Are you able to tell me exactly which part I need and if you have it available?
    Top Expert:
  • Mitsubishi Master
  • 75,807 Answers
The best thing to do here is just replace the TV, new LED and LCD TV's are very cheap and have much better image quality.
Posted on May 19, 2017
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Posted on Feb 03, 2008
  • 927 Answers
SOURCE: Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Posted on Jul 25, 2008
mastersaintx
  • 928 Answers
SOURCE: Mitsubishi TV Model #ws65869 Blinking Green light
Sorry for the late reply I just got up.
From what I understand of your problem it is most likely a blown capacitor or main IC. Unless I can open up the unit and test the IC's and capacitors I can not be really sure which is why I hardly answer questions about TV''s as they are hard to troubleshoot without the unit in front of you. Ive found a site that can help you via a service manual since I could not find the exact service manual for you from my manual book. The site also has the parts that you will need if ever im right and it is the capacitor or IC. As for the IC's by experience is hard to test without an Oscope but you can do it by gradually eliminating the problem, again you will have to refer to the service manual regarding that. By the way the capacitors I mean is the one that goes to the main module as that is what powers the controls for the TV. the green light is just the "pilot light" which means you have power to the TV but the power is not going past the capacitors to the main controls or the main IC. So simply put the problem can be the capacitors (Which is what you check first) if they are ok then look at the IC via using a service manual. You can use a multitester for the capacitor first if they are dead then just change them and you should be ok. Let me know what happens or updates ill reply to them as well.
Posted on Sep 02, 2008
daniel719
  • 240 Answers
SOURCE: Mitsubishi WT-46805 convergence resistor location and vlaues
5a resistors are all 120 ohm 1/2 watt use flame proof resistors.
check fuse f9a23 or f9a22
also replace knowen bad caps in this unit efecting convergence replace all 10uf @ 16v on the scan doubler module, ther are 8 off them.
make shure and check trace between Rg-8 and r705 for a open, sumtimes fulid from crt will open this up.
regards
daniel.
Posted on Jan 13, 2009
asnowman
  • 788 Answers
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I think that you have two that are on the board in the center of the set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on May 29, 2009
I have a WT-46805 Mitsubishi rear projection tv. The screen was accidentally pushed in and now has a crease. It was also missing the protective glass in front of the screen. I also have a broken model...
Check following image taken from related service manual that shows how to take off front screen from WT-46805 tv.
Hope this info will help you.
Please click HERE to download service manual copy, if required. It has schematics, parts list, exploded views and all technical info of WT-46805 tv. (service manual is available for 2 days only)
Thanks.
Nov 13, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Tv went blank and now there is a popping sound thru the speakers
try putting new batteries in the remote...see if that wont help
Dec 31, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
MITSUBISHI WT-46805 No Volume
Sounds like audio output IC is bad.Hope this helps. It is on the center circuit board on a little heat sink directly in front of the large Convergence heat sink. It is referred to as IC3E01 and the part number is LA4663. Hope this helps. Let me know if i can assist you further.
Nov 05, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Good Day, Corri;
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
