Question about Sony KDF-50E2000 50" HDTV
I replaced the bulb on th SONYKDF-50E2000. I broke the right arm off the outside lamp cover. The bulb seems to be seated well but I get the 3 red lights when I tun it on. The green light lasts 2 seconds the fan starts then everything stops and the 3 red lights flash. Any thoughts?
    Genius:
  • 1,030 Answers
Yes this arm on the lamp cover is essital .. this arm push a switch close that tell the set the door is closed.. the three blinks is the error code for the door not being closed. can u glue the peice back on.... or else you might have to get another cover
Posted on Mar 18, 2011
I have a sony kdf50e2000 done a normal cleaning on it earlier..t was working fine..took the buld out and cleaned around it..put it back together..and it only came on for like 3 min then went back off..red...
This is an error code for "lamp cover" and "lamp itself" not properly seat in to the housing. Re-install the lamp, make sure that all of the connectors are properly connected. Ensure that the lamp cover is attached securely or else the same symptoms will be encountered.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
Having a problem getting past the red blinking status and orange blinking when trying to start up a NEC VT595 projector. This is after installing a new bulb.
I have had the same problem with my NEC VT695, however, while trying to repair it, I actually broke off two pieces, first the arm that is attached to the lamp cover that depresses the button, and then the actual button itself. Does anyone know any way to bypass this need to have the lamp cover seated 'properly'?
Jul 13, 2011 | NEC VT595 LCD Projector
Just replaced the lamp, worked for about 3-4 days, tv won't turn on, green light flash about 3-4 times then a red light flashes, waited about two days, tv came on and worked for about 1 month now the same...
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
Jan 20, 2011 | Sony KDF-50E2000 50" HDTV
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
Try to start sony kdf-50e2000 tv and wil not start and red light keeps flashing. what does this mean?
You will have to replace the lamp which goes every 3-4 yrs depending how often used (Sony XL-2400 DLP replacement lamp).Your instruction booklet will explain this page 76. As further info I would also make sure the lamp comes with the cover which Amazon has it for a total price of around $130.
Dec 14, 2010 | Sony KDF-50E2000 50" HDTV
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
Getting a message that my lamp is nearing the end of it's life. I have 4 questions: 1. How long do you think I have until it will burn out. 2. Is there only 1 bulb/lamp that will need to be replaced. 3....
Hi, my same Sony KDF 50e2000 has been giving me the "proj lamp near end of life" message for approx 6 months-and we watch a lot of tv/play wii. I just ordered a repl lamp on line
Sep 01, 2010 | Sony KDF-50E2000 50" HDTV
Sony KDF-50E2000 50" Lamp replacement
1.you have 10hrs
2.you can find them everywhere try eBay
3. It is easy except one thing you must have the original remote to reset the lamp counter
May 16, 2017 | Sony KDF-50E2000 50" HDTV
Sony KDF-50E2000 50" HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
