Question about HP LaserJet 4700 Printer
Ny HP 4700dn iwill print one page of my last job and then be stuck on processing. If i turn it off it does the same thing again. Anyone know what I can do to fix this?
  • aarons224 Mar 18, 2011
    The computers on the network are all running windows XP. I'm guessing I would need to do this on the computer that did the original printing? It was fine this morning and then it starting doing this about 30 minutes ago.
    30 minutes later it printed the rest of the 4 pages for the file. Now it's stuck on processing again.
  • HP Master
  • 1,591 Answers
If you are running Vista or Windows 7, go into the printers from control panel, and go to the printer properties and uncheck bidirectional communication.
I can't give total step by step because I don't know what OS you are running, but that's the main thing to do is turn off the bidirectional communication in the general tab of the printer properties in the print driver.
Posted on Mar 18, 2011
  • Norman Skinner
    Norman Skinner Mar 18, 2011
    That helps a bit. In that case, I'd be checking the network cable to the printer.Unplug it and plug it back in....it may have just come loose.
    Make sure a careless cleaner didn't nick the cable with a vacuum cleaner.
    Sometimes delays can occur if the printer changes it's IP address too, so that's another thing to check on. Usually if that happens, things go bonkers for about an hour until all the machines find the printer's new IP address.
HP Laserjet 4700dn suddenly stops printing in color although the cartriges are new and were working well. What is the problem?
>Go to menu settings, select set as default setting, do color calibration.. try for the print..> take configuration page, verify the firmware version, if low, download from hp web site, up load as specified..
Feb 01, 2012 | HP LaserJet 4700DN Printer
I have a HP 5610 all in one printer, the problem is the printer starts to print out the paper but in the middle of the print job it stops and says on the display window (paper jam) don't know why every...
I don't mean to suggest things that you've already tried, but check out this page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125&tmp_track_link=ot_search
If you try all the steps and still have a problem, the last solution is to service the printer. But make sure you follow all the steps as shown on that page before assuming the worst.
That's not the best news - sorry.
Jan 25, 2011 | HP Officejet 5610 All-In-One InkJet...
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Sep 07, 2009 | Sharp MX-2300N Color Copier
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
XEROX 2424 is printing in reverse order
Check your driver settings, in Layout option some people things that print in reverse order is going to print on both sides but its not. It wil print your job backwards though. So make sure you dont have that selected
Oct 20, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
I tried to default printer because, it showed printing 18 pages and I did not want it to print all now it is stuck with 1page 1/4of the page sticking out of the printer. What should I do ??
Cancel all of the print jobs in the queue.
Open the printer, highlight the print jobs, right click and choose "Cancel"
Then turn the printer off, reboot your computer, turn the printer back on while the computer is rebooting.
That reset the entire printing process.
Aug 17, 2008 | HP Office Equipment & Supplies
Printer malfunction
it means that the spooled pages was somehow interrupted in the process, either by power interruption or by any means, pls cancel all documents that was queued from your PC and restart again, the printing once again. and cancel the printer button as well from the printer, if there is still some jobs awaiting to be print
Jul 25, 2008 | HP Office Equipment & Supplies
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP LaserJet 4700 Printer Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
