Question about HP Media Center M1050Y PC Desktop
I have an HP m1050y Media Center XP desktop pc, and I need to replace the video card to run some new software that requires OpenGL2.0 support. The software manufacturer suggested upgrading to at least a Nvidea GE Force 9800 or above, or the ATI Radeon 4xxx. For additional performance they suggested the Nvidea GE Force GTS or the Radeon 5xxx. My question is will these newer suggested cards fit and work on my old pc? Also, are other hardware upgrades necessary to make this all work such as power supply. This system currently uses a 300w ps. Appreciate any suggested answers so that I can pursue purchasing the correct components.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 12 Answers
These newer video cards should be able to fit in your computer. According to HP, you have a PCI Express slot, which is what the video cards use to communicate. It is a first generation slot, however, so you won't get maximum performance out of a lot of the newest or highest end cards. One of the 9800 or 4XXX series cards should do nicely. The only other thing you should be concerned with is the power supply, which should probably be sufficient, wattage wise. All these video cards require a direct connection to the power supply, so you need to see if your power supply has the connectors required. You will need either a dedicated video card connector, or 2 molex connectors, which is probably what you'll have. Molex connectors normally attach to hard drives and CD drives. They have 4 pins in a single row and there are usually multiple connectors on the same cable. If you have 2 of these open, you can use an adapter to convert them into one of the PCI power connectors, which has 6 pins in 2 rows. The video card might come with one (they often do), but if it doesn't, one shouldn't cost more than a few dollars. Good luck!
Posted on Mar 18, 2011
Testimonial: "Thanks for providing an excellent solution to my question regarding both video cards and power supply. I purchased a 9800 today."
Can I install pci-e X 16 2.1 video card onto my HP Pavilion Media Center m8400f PC
Its a slot distribution both 2.0 and 2.1. 2.1 is a bit faster as it leads with version. You can install any VGA card that supports it but keep it in your mind that more heavy vga card will require more power. So, you power supply should be heavy and should bear more power for your card as well as your system.
Sometimes, it require to change the power supply as well.
best of luck!
Mar 17, 2012 | HP Pavilion Media Center TV M8400f Pc PC...
I replaced th original Ati radeon x300 video card on my hp media center m7250n for a new galaxy gt 240 for better video and also changed the power supply to a new 550 watts. Since I lost audio. The system...
Hello
The x300 is video only.There is a possibility you may have knocked your sound card out of its pci slot while working inside the case.
Check that the sound card is firmly seated in the slot.
If you do not have a sound card and are using onboard sound,reinstall the sound drivers.
Enjoy your new gt 240.
Feb 06, 2011 | HP Media Center m7250n (ED842AA) PC...
My HP M7260n doesn't recognize my new Video Card...
You might need to uninstall the old video card device, so Windows does not use the old drivers for the new card.
Another option is to try and boot in Safe Mode (press F8 during startup), so Windows uses the VGA mode (which all video cards support), and then install the proper driver.
Installing the latest ATI driver updates might also not be a bad step.
Jun 25, 2010 | HP Media Center m7260n (EG642AA) PC...
Does the presario sr1920nx have a vga card that supports tv?
If the os is windows xp Media Center or Windows Vista Media Center then it directly supports tv viewing and no additional card is required.
May 28, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
I have a HP media center m7360n , with a 920 intel pentium D processor. I changed the video card which required a more powerful power supply. I upgraded the ram and changed the power supply out to be...
Open your computer casing where the motherboard lies in and then remove the memory card, your new video card and then reset the BIOS, refer to the motherboard manual on how to do it. After resetting, plug in the memory card and video card. Close the casing and connect all the wiring. Power up your computer.
Nov 03, 2009 | HP Pavilion Media Center TV m7360n...
Bad video board? Trying to figure out is card is bad or if it's drivers.
I agree, it does sound like it is on its last leg. Keep the settings on low and run it til it dies!
Apr 22, 2009 | HP Pavilion Media Center M1090n (PC100A)...
HP Media Center m1195c PC
It's a rather indepth process and is usually just easier to replace the computer.  Motherboards have many different adapters / slots / options.  If you're meaning to replace the motherboard and processor cpu, it'd be best to buy a package deal from newegg / tigerdirect / etc.  To be able to use your other components, you'd have to make sure the new motherboard has the same type memory slots, video card slot, etc.
Sep 22, 2008 | HP Media Center m1195c (PJ475AA) PC...
Hi, I just got a new pc HP Media Center M8430F, and I am not able to record stream audio or internet radio
I have an HP with Media Center as well.
Generally you need a software program that specifically records streaming audio and or video. A freeware program I use is OpD2d. Google it and install. Very simple to use.
Apr 16, 2008 | HP Media Center m7250n (ED842AA) PC...
Video is scrambled
It's probably something to do with your video card. The card could need replaced or there could be a bent pin in the plug. Check for the bent pins first.
Nov 19, 2007 | HP Pavilion Media Center TV m7360n...
HP Media Center M1050Y  PC Desktop Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
