Question about Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
Keeps coming up E4Pressure cooker - Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
    Scholar:
    New Friend:
  • 135 Answers
Here is a piece from someone who had the same E4 error problem:
I had this problem. I noticed that steam was coming out almost immediately and the cooker would not start counting down. Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle. The plastic cover was so far down on the metal piece that it would not allow the metal cylinder to seat on the vent. You can use the metal piece by itself or work the plastic cap up far enough so that the metal piece seats on the vent in the closed position. I have had no more problems - it works fine. good luck! kc
Posted on Mar 18, 2011
My cooker keeps releasing pressure during cooking & there is therefore no pressure to release at the end of the cooking process resulting in uncooked food
Your valve is leaking. You may be able to replace it or repair it. It is usually easier to replace the cooker, unfortunately. Sorry.
Dec 30, 2015 | Instant Pot IP-Lux60 6-in-1 Programmable...
I have a wolfgang puck pressure cooker that keeps shorting out and tripping the gfci within 1-4 minutes. What can I do?
You may have a faulty GFCI...test it and again with a known good appliance.
If the GFCI holds, then you have a ground fault in the pressure cooker. Either disassemble the cooker to the electrics and fix the short or return the cooker under warranty.
Chances are you can even get a replacement outside of warranty if you talk nice to the company.
Google it and get the company website.
If you bought it from bed bath and beyond just return it, hopefully with the receipt.
Feb 25, 2015 | Wolfgang Puck Crock Pots & Slow Cookers
How to use the slow cooker on the oval cooks essential pressure cooker
I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy, if your gone for even 10 hours it keeps your dinner warm after the cooking time runs out. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of the same shape the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker and the lid fit, now I also have a removable pot replacement as well just in case I smash that too. So happy I have my Slow cooker back again.
Dec 05, 2013 | Deni Cooks Essentials 5qt Oval Pressure...
Russel Hobbs RHNPC800P Slow cooker keeps blowing the thermal fuse. What would cause this???
two things, the thermostat allows the cooker to get too hot or the thermal fuse rated temperature is too low. Try get a thermal fuse with about a 10 deg higher rating.
Apr 18, 2011 | Russell Hobbs RHNPC800P 8-Quart Slow...
Can you boil in a slow cooker?
Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
My wife's slow cooker boils even on the low setting -slowly, but it boils.
Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
Error code keeps flashing wont pressure up and they wont stand behind their product
The vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Mar 09, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
West bend slow cooker model 84866 lost power cord, repl part on their site is 5.99 but 7.95 for shipping is ridiculous
I found this one on eBay but do not know if it will fit your machine. It is a little less expensive and is used. Replacement parts are always expensive but less than buying a whole new machine...much less it keeps it out of the landfills. http://cgi.ebay.com/VINTAGE-WEST-BEND-SLOW-SLO-COOKER-REPLACEMENT-CORD_W0QQitemZ320494123773QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US?hash=item4a9ef03afd
Feb 20, 2010 | West Bend 84866 6-Quart Slow Cooker
The plastic lid is broken and the off -on swith keeps coming off!
I only want the black knob that lifts the lids off -
it cracked on its own accord - posibly the heat as I use it a lot -
Nov 19, 2008 | Russell Hobbs RH-SC600 6-Quart
Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver Logo
406 people viewed this question
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
Sloop Johnb
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
