Question about Microwave Ovens
Kenmore Microwave Displays Error Code Reading "Prob"
Within 2 seconds of "Start" my Kenmore model 721.8943580, manufactured 8/90, beeps, stops, light goes out, and LED display reads "Prob."  "Clear", reentry and "Start" bring same error. If hours or a day go by before restart, the unit runs fine for up to a minute or more before shutdown and "Prob" indication reoccurs.  Then, an immediate attempt to run the unit again results in the same condition in 2 seconds.
I use this old unit, otherwise in top condition, only for heating water for tea.  Spending big money on repair doesn't make sense.  Could the fix be as simple as a cleaning?  I've replaced bulbs and belts in MW ovens and I'm an experienced do-it-yourselfer with complex appliance and other repairs.
  • Fred3x3 Aug 10, 2008
    Thank you, MicrowaveSvc!
    The obvious professionalism, completeness and rapidity of your response are both unexpected and appreciated.
    Some days had passed before I planned to remove the unit from its high shelf.  Before doing so, I decided to try to heat a cup of water, again, and much to my surprise, I've been able to continue to heat my tea water in the microwave for two days, as of now.
    I'm sure that these are not the kind of problems that cure themselves permanently and, at some point in the future, I may have to followup with your suggestions.
    If I should have to open the unit, I'd also clean its innards well to make make sure the efficiency of its internal ventilation system is not compromised, etc.
    My problem had occurred during particularly humid weather, but the microwave is in a space that is air conditioned in such weather.  Would we expect to find a humidity probe as well as a temperature probe in a microwave that's 18 years old?
    If the problem recurs and I open the unit, I'll let you know the outcome.
    Thank you again.
  • Microwave Ovens Master
  • 9,086 Answers
I would bet that the temperature probe socket has some accumulated grease, etc. in it which may be changing the resistance of the contacts, making the control board think the probe is installed but defective.
First, please unplug the oven before you investigate.
The best idea is to clean the probe socket contacts.
You'd need to remove the outer cover, and the probe socket should be located on the right side of the chassis.
If you can cut thin strips of fine sandpaper and work them back and forth between the contacts, that's the best way.
You can plug & unplug the probe while observing the socket to see how the contacts work.
Your socket may be sealed, and that would possibly require you to carefully take it apart. That's a bit of a gamble, as it may crack due to age.
Another idea is to take a wad of paper toweling, hold it with your right hand over the back of the probe socket, and spray contact cleaner or WD40, etc. into the opening of the probe jack from inside the oven cavity with your left hand.
Then plug & unplug the probe several times, wipe any spills and try the oven again.
If the probe unplugs form the control board, you could disconnect it and try the oven.
Let me know how it goes.
Posted on Aug 02, 2008
  • William Miller
    William Miller Aug 11, 2008
    The parts list does not show a humidity sensor.
    If you do decide to clean the probe, I would just focus on that. As they say, "If it ain't broke, don't fix it!"
    You can find exploded views and order parts by entering your model number here at the Sears parts site.
    The temperature probe is shown in the "cabinet" sectrion of the breakdown.
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
Aug 07, 2014 | Kenmore Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
Upon plugging in the microwave, several beeps are heard and the touch screen displays "Touch Error". After a few seconds the error message goes away but the touch pad is not functional. The Kenmore model...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a full one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 08, 2010 | Kenmore 63792 Microwave Oven
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
How to stop the beeper and reset the "code' light on panel?
You have a shorted 2 pad on the keypad.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Aug 21, 2008 | Microwave Ovens
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
Microwave Ovens Logo
325 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
