Question about HP Photosmart 3310 Printer
I have a hp 3310 all in one printer. I have a a error Oxc18a0001 come up when when i do what they say hit * and hold # i get and enter special key combo i get 123 i get R0045 and thats not the code they say you will get and thats as far as i get.
5 Suggested Answers
Rider On Way
  • 1679 Answers
SOURCE: Having difficulty getting my HP photosmart 3310 to
There are several special key combo for ex. 1-2-4 and 3-2-9 also 1-2-7 depending on the purpose of using it.
My suggestion would be,
Remove the cartridges,
Clean the golden ( electrical contacts ) with lint free cloth
Put the cartridges back and check if the error message disappears
If not,
Try the Full reset following these steps
Disconnect the power cord from back of printer ( while printer is on )
While holding the # and 6 button, connect the cord
( if you do this reset, the printer will loose all the memory it has stored like fax logs, will get disconnected from Wireless network )
The error message is likely due to a cartridge expiry date and certain printers do not accept such expired cartridges from present date. Try replacing such cartridge
Posted on Oct 12, 2010
  • 11 Answers
SOURCE: HP 3210 Ink System Failure error code 0xc18a0307.
Solution To resolve the issue, use the following steps. Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
Reset the HP All-in-One
  1. Turn off the HP All-in-One by pressing the On button.
  2. Unplug the power cord from the wall outlet and the back of the HP All-in-One and leave it unplugged for five (5) seconds.
  3. Plug the power cord back into the wall outlet and the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the On button.
I f the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
Posted on May 03, 2009
  • 73 Answers
SOURCE: After replacing color cartridges I get the
try pressing buttons in sequence blue then green then grey it should take you to a special menu look for reset meni and select semi full reset if that does not work try removing the cartridges while machine on pull out power cord wait 15 seconds plug power back in insert cartridge when promted on display screen
Posted on Jan 26, 2010
SOURCE: errore stampante HP 3310 All
Re-initialize your printer by performing following instructions: - press OK and delete (X) at the same time - disconnect the supply cable 220 V - wait 60 sec - connect the cable, your printer muss start automatically, when not press the Start button. - you can select the language and country.
Good Luck Philippe
Posted on Nov 28, 2010
Hpc6288 error:oxc18a0001
Resets for all HP all-in-one printers with keypads: 1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold "# and 6′ keys.# and 3,# and 9
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you
Jul 06, 2011 | HP Photosmart C6280 Printer
Errore stampante HP 3310 All in One Oxc18a0001
Good Luck Philippe
Nov 18, 2010 | HP Photosmart 3310 Printer
Hi! I get an errorcode regarding the inksystem on my Photosmart C8180 that says: Oxc18a0001. I´ve tried some steps via HP.com but they didn´t do the trick. Do you have any ideas? Patrik...
Hi Patrik
This error message comes when the ink system fails to work properly
Please follow the following steps to resolve the concern
1. Hold Print Photos & Red Eye removal together and the printer will show enter special key combo.
2. Press the red eye removal, print photos and red eye removal in sequence
3. The printer will show support menu
4. Press the right arrow key twice to go to the reset menu
5. Use the right arrow key to go to the semiful reset
6. Toucj=h the semiful reset and it would restore everything to the factory settings
That might work for you
All the best!!
Oct 28, 2010 | HP Photosmart C8180 InkJet Printer
Having difficulty getting my HP photosmart 3310 to print! Tried all the suggested reset options etc. even was able to get to the 'OVM reset', however, I'm still getting an ink failure msg... and when I...
If not,
Oct 12, 2010 | HP Photosmart 3310 Printer
0xc18a0001
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Jun 02, 2010 | HP Photosmart 3210 Printer
Error code oxc18a0001 on an HP 3210 HELP
this is an ink error code:
try the following;
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again
Jul 31, 2009 | HP Photosmart 3210 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
Ink system failure
Step1: Get into support menu by following the steps:
Press & hold the * Key then press # key.
Display says “enter special key combo”, Press OK on it.
Press & release 1, 2 & 3 keys in sequence.
Display says “Support” & FW rev. then go to Step 2
Step 2:
a. Press and release the right arrow button twice.
b. Display should say “System Configuration Menu”. Press and release the “OK” button.
c. Display should say “Hardware failure status”. If not there already, press the right Arrow Key over to “Hardware failure status”,
d. Press and release the “OK” button.
e. Display should say “Hardware failure status: Clear. Press OK to clear”. Press and release the “OK” Button.
f. Display should say “Hardware failure status Cleared. Press Cancel to continue”.
g. Press and release the “CANCEL” button as many times until the “Welcome to Photosmart Express” window appears.
h. Turn the unit off and then on by using the power button on the control panel, continue with the installation/setup of the unit.
1. If the error is still there, then perform the power cycle.
If it works it is good, if not if your printer is in warranty you will get the unit replaced for free from HP.
If not call HP and get a Out Of Warrnty Upgrade option where you will get a good discount,
Call 1800 474 6836
Good Luck
Aug 13, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
