What kind of power cord is needed for this? I bought it used and did not realize that the power supply was different.
  • Tony Mar 18, 2011
    what is this?
    please clarify
    Problem Solver:
  • 18 Answers
Go to a local electronic store and ask for assistance. They will give an idea of what cord you will need. From there, you can buy the cord online if the price is too expensive.
Good luck.
Posted on Mar 18, 2011
I need the cheapest power supply cord for a hp deskjet f340 asap. Please help
Any office supply store. Check which kind your printer uses but all that cords are standarized
https://www.cablestogo.com/learning/connector-guides/power
Mar 02, 2018 | HP Office Equipment & Supplies
Can i use an alternate power supply for my wii? if so what kind
there are different kinds or power supply that you can use..the most important things are the specifications on the original power supply will match with the alternate power supply that you will buy. As long as they match there will be no problem on using different power supply...
hope this info help you and goodluck on finding you new power supply
Jan 13, 2012 | Nintendo Wii Console
I cannot turn it on...when I use the same cord on other printer/scanner, the cord is still okay..so this means that the problem is on the printer/scanner....kindly advise what to do....
Since the power cord works on a different scanner, this means the power supply unit inside the printer has failed. In most cases, this costs more to fix/repair than a new printer.
Feb 28, 2011 | Office Equipment & Supplies
The ac adapter red light stays on and the counsole will not work
This problem occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if one of the following conditions is true:
• There is too much current.
• The voltage is too high.
• The temperature of the power supply is too high.
When any of these conditions are true, the light on the power supply turns red. Here are some steps that you can use to try to fix the problem.
Step 1: Make sure that the power supply is cool
The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
1. Make sure that your Xbox 360 console is turned off.
2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
4. After the power supply has cooled for two hours, reconnect the Xbox 360 Power Supply to the console and to the wall outlet.
If cooling the power supply does not resolve the problem or if the problem persists, use the steps in the next section.
Step 2: Make sure that the power supply is plugged in correctly
Make sure that the power supply is directly plugged into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
If the power supply is still not working as expected, use the steps in the next section.
Step 3: Plug the power supply into a different wall outlet
To eliminate the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a different wall outlet in a different area of your place of residence.
If this does not resolve the problem, use the steps in the next section.
Step 4: Try another Xbox 360 Power Cord and Xbox 360 Power Supply
If you have a different Xbox 360 Power Cord and Xbox 360 Power Supply, try to use them to test the console. If the console turns on when you use a different power cord and power supply, you need to replace the faulty power cord and power supply. If the console does not turn on, the issue may be with the console itself.
Step 5: Obtain a replacement Xbox 360 Power Supply
If the steps in this article did not resolve the issue and the Xbox 360 Power Supply light continues illuminate red, you need to obtain a replacement power supply.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Microsoft Xbox 360 Console
Power cord isn't working for Acer 5720
I have had good success with this notebook universal power supply. Just make sure that the clip you need is included with the item. Or you could buy an OEM (original equipment manufacture) model.
Hope this helps.
http://www.cablesunlimited.com/products/Prod_Individual3.aspx?groupcode=I3550
Nov 05, 2009 | Acer (56.04145.901) (5604145901) Power...
Need to replace power cord and projection tube
What CRT do you need? Each one has a different part number. Realize that each CRT will cost about $200.
Dan
Apr 23, 2008 | Panasonic PT-53WX53 53" Rear Projection...
DELL 600M AC POWER CORD
The internal power supply of your PC is broken, it needs to be serviced.
Feb 13, 2008 | Dell InspironTM 600m Notebook
Computers & Internet Logo
David Payne
David Payne
