Question about Canon S900 InkJet Printer
The black color is not printing (and there is black ink in the tank)
    Sergeant:
  • 187 Answers
Before you print Click on the Properties button. Click the Color Tab\Print in Grayscale\Black ink only
See image for reference.
Posted on Mar 18, 2011
Wrong Color Printing
Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Thank
Jan 09, 2014 | Dell 1320c Laser Printer
Cannot print
Change the cartridge ...
but, in case E3
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Mar 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
New black cartridge installed. Won't print. HELP please.
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Cartridge recommendations
You can purchase Canon cartridges directly from Canon here. The BC-10 is a cartridge that prints with black ink only. The BCI-10 is the replacement ink tank for this cartridge (a new cartridge comes complete with an ink tank). The BC-11e is a cartridge that prints both black and color, and has two ink tanks, the BCI-11 black and BCI-11 color. A new BC-11e cartridge comes complete with two new ink tanks.
Oct 03, 2008 | Canon BJC 80 InkJet Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon S900 InkJet Printer Logo
81 people viewed this question
old marine
old marine
