Question about Acomdata (HD160UPE5-72) (HD160UPE572) 160 GB Hard Drive
My PC is not able to read my Acomdata portable hard drive. Any suggestions how I can repair on my own? Thank you.
    Scholar:
    New Friend:
  • 135 Answers
OK, before you take it to a specialist in physical drive damage for recovery, have you tried it on another computer? The most important thing now is for a computer to at least pick it up in "My Computer" and assign it a Drive letter such as E:/
If you can get that, there are a few free programs such as data recovery software online that can help you retrieve all files and fix sectors of the hard drive. good luck
kc
Posted on Mar 18, 2011
    President:
  • 2,653 Answers
Try hooking up the hard drive to another computer, what happens? Which version of Windows are you using? Was the external drive ever connected to a MAC?
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    USB broken
    Pop in to your local PC shop. You should be able to buy a new cable relatively cheaply.
    Dec 10, 2013 | Computers & Internet
    Can't access the files anymore. how can I retrive them?
    If the hard drive itself is damaged, your files may be permanently lost. There are companies that will attempt to recover your files from the drive for a fee... that usually involves sending them your drive with pre-payment. They will often disassemble your drive in a clean-room environment and transfer your disks to another identical drive then try to access the data. If the disk surfaces are damaged, files on the damaged areas are usually not retrievable...
    If you purchased the new case, as the company recommended, then properly moved your drive into the new case, it is likely that you will have to resort to the recovery scenario above.
    http://www.werecoverdata.com
    https://www.fields-data-recovery.com
    Aug 28, 2017 | Acomdata PHOTON 2.5 (PHD080U2E54) Hard...
    Problems with Hard Drive
    Appreciate the direct "Ask Me".
    T your concern:
    • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
    • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
    • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
    • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
    • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
    • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
    • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
    • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
    • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
    • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
    • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
    • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Acomdata PHD160 didnt work for Window VISTA
    My probleme is who to get drivers to install it on my PC.
    Thank you.
    May 09, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
    Acomdata Portable Hard Drive
    I upgraded from Mac OS 9.1 to Mac OS10.5 and the new system will not read my hard drive. Can you help?
    May 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
    External hard drive will not turn on
    Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
    Keep me posted.
    Oct 08, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Acomdata (HD160UPE5-72) (HD160UPE572) 160 GB Hard Drive Logo
    123 people viewed this question
    Top Acomdata Computers & Internet Experts
    Jerry Umali
    Joe Goldman
    Joe Goldman
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
